Over the past couple of months, with the help of this forum, I have been bringing an R33 GTR back to spec. With replaced steering rack, new shocks, tyres, reconditioned mags and a few other things it is now going well. Sits rock steady at 170-no vibration whatsoever.
But now it is to the air con. The compressor is not working. I have ordered a working compressor from an R33 GTs-T. mIt looks exactly the same except for the backplate where the connection for the suction hose has been changed for what I guess is clearance.
Has anyone modified this compressor to fit a GTR? What I was thinking of doing was changing the backplate from my GTR compressor to this GTs-T compressor. It should then connect straight up to the GTR hoses. Has anyone done this? Advice please.
My first concern would be the back plate gasket-can it be reused?
Thanks.
https://www.sau.com.au/forums/topic/416071-r33-gtr-air-con-compressor/
I would think its a metal gasket so yes it can be swapped if the pattern is the same. Make sure the S and D symbols are both on same sides etc.
Have back plate facing up if you don't wanna lose the oil but I would drain it and get new oil when its gassed up
Nothing goes as planned! Well the used compressor arrived. But now I have a new problem-hope someone can advise a solution.
The outlet and inlet holes on the compressor are slightly larger then my compressor-about 2 to 2.5mm larger in diamater.
I realise an obvious solution is to try to get another compressor with the same size opennings as my original compressor. Also to possiblt see about changing my hoses to get the right size connections.
But has anyone had this problem (it seems Nissan made this change through the life of the R33) and found a solution to use the compressor with my original hoses that have been made to be a very snug fit in my original compressor. When I put my hoses into the openning of this used compressor with the larger openning there will be at least 1mm play around the fittings.
Help! Any suggestions most welcome and appreciated.
Just to let everyone know how things worked out. My very helpful local Auto Electrician Macca's rumaged through his collection of O rings. We found some larger O rings that were a fairly close fit for inside and outside diameter. Much thicker then the original O rings. Fitted these. Both of us were concerned due to the amount of play, so I also put some v good gasket cement above the O ring of the outlet and between the aluminium mating surfaces at the top. The gasket maker was also rated for refrigerant use.. This may not have been needed.
Once together tested the system to 250lbs pressure. All ok. Job is now finished and air con is working beutifully.
Next job is to make up a new floor for the boot. Threw out the old one as it had been wrecked by the previous owner(s)? installation of copious amounts of hi fi gear which I removed. Once this job is done the GTR will be back to standard with all working well throughout the car.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
