Hey Guys,
I've searched the forums and found some info on the wheel bearings for M35 Stageas. The DIY bearing change was great and elucidated the procedure, but we can't seem to figure out which bearing needs changing.
Above 40km/h you can hear the hum start to wind up and the pitch goes up as the car's speed increases.
When you turn right and load up the left side (above 40km/h) the hum gets louder and more groan like. It sounds like its coming from the front of the car.
So, I go the part 40210-AL800 (from DIY thread) and got the local mechanic to change it (3hrs labour x $90/hr).
The noise is still there.
My question is: Is it possible for the rear wheel bearing hum to sound like its coming from the front on these cars?
Mine is a 2002 Autech Axis. You can see it was driven in a snowy area in Japan because there was a bit of salt on the rear end and some corrosion on the muffler. Other than that the car looks brand new and has 45k on the clock.
Other troubleshooting:
- Tried the spare on each corner to see if it was tyre noise (no change)
- Jacked up each side and tested for play in the bearing and spun for any noise (none)
Thanks a lot guys
https://www.sau.com.au/forums/topic/416083-wheel-bearing-sound-travel/
Just want to clear something up here..
You supplied the mechanic with the wheel bearing?
If not guarenteed he didn't change it for $270 including parts considering the bearing is around $250 alone
Bearing can be purchased for just over $100 on eBay from the US.
I read the post as the LABOUR component of the task was $90 p/h, no mention of bearing in the price.
Change the other one. You may have misdiagnosed.
They've both done the same number of kays, if one is stuffed, the other on the way.
Edited by Daleo
Yes I got the bearing from Steve Jarvin Nissan and supplied it to the mechanic. So you think it could be the other front one? I don't understand how the front driver side could be bad if it is noisy when I turn right?
Thanks for the help guys.
So should I change the front driver side bearing instead of the rear passenger one?
Sometimes I get a shudder like this one when I bump the synchro button:
http://www.skylinesaustralia.com/forums/topic/405046-front-end-shudder-under-power-and-steering-lock/page__st__20__p__6609715__hl__shudder__fromsearch__1#entry6609715
I cant work out if I Have a bearing problem, at the front left, or if my tyres are causing the noise.
It sounds like a low rumble increasing with speed.
No play in the wheels and turning left and right quickly at low speed doesnt seem to generate any significant noise or anything unusual. There is a slightly more rumble noise on the turning component of the tyres as they turn.
i jacked up car and tried to move the wheels sideways but they seem pretty solid. No lateral movement.
If I move the tyres backwards then forwards there is a slight clunk.
Just roting the wheels they seem almost quiet.( it is not noiseless)
Can I ask what tyres you are running . I am running 225 45 18 dunop venturo at 41 psi
PSI is a bit high but from all repeort s this level gives better handling.
What tyres are you running?
What does your noise sound like ( any addtional details)
Same tyres as you Samuri. Mine doesn't make any noise until 35km/h then a low hum increases with pitch and volume as speed increases. Same here, no rotational noise and no play. Going to take it somewhere and put it on the hoist.
I definitely have a bearings
problem at the very minimum.
Making the turn right actually increases the sound on the left front bearing,
because of the additional load , putting pressure on the left front
bearing.
must the unit be replaced or can a specialist bearing
compAny fix it? What's the best solution and why?
confirming part number is 40210 Al 800
My front passenger side was changed by the local mechanic who has a press. Ordered the part from Nissan.
What I would really like to know is why do they go in the first place? How many kms on your m35?
Just for interest sake what did they charge you? I just done it myself and wondering what I saved.
270 for 3hours labour for one side. Is it design fault why they don't last long or could it be that they are used in snowy/salty areas in Japan?
Edited by tommysbeast
Changing wheels/alloys to a non standard offset can also change the load characteristics placed on the OEM bearing and assist in their premature failure.
Unless you have original log books for the car, i wouldn't place a great deal of faith in the KM's on the ODO either so this might not be the best indicator to go by.
Edited by HER_M35
Mine have done over 100,000km, I think that's a pretty decent life for a bearing that takes the kind of load they are subjected to.
Not really a design fault, peoples expectations of mechanical component life expectancy is the issue here.
Agreed any car would probably need one at around 100k. Add to that our cars are high powered nd heavy all wheel drive cars pretty sure it is going to put a lot more wear them a general car
Before you go spending heaps on wheel bearings, i would put it on stands or a 2 post hoist and run it up in gear, use a screwdriver or stethescope on hte hub to determine what is the problem. I seriously doubt a wheel bearing has gone at 45,000km, even 100,000 is fairly unusual, but not unheard of
+3hours to press one in is a bit steep. Should be able to comfortably do it in 1.5
Edited by Adriano
While i agree with you in theory on the time it "should" take, these can be a pain in the ass when they're rusted in and eventually need to be be cut/ground from the hub.
3 hours is about right if they want to stubborn.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
