List price through Nissan is $1300 ex Japan ...
Cheap as :P
I always thought the Hitachi CAS was easier to rebuild but apparently not? probably should of had a go at my spare broken CAS today but forgot all about it.
So I pulled one of my spare CAS apart yesturday and all went pretty good, I had to drill the pin that holds the engagement drive out and bent the pickup disc a bit. Not sure if the new sensor comes with a new disc? I was thinking about just using a roll pin (Cutting down to size) in the hole for the engagement drive
Is there any parts list at all for these? Bearings are easy enough to replace but the rest of the stuff not so much
So bearing is easy enough without doing any damage? My bearing is a little notchy.
you have to pull the engagement drive off the shaft to get one of the bearings off. To do this you need to get the disc out of the sensor. I think you can unscrew half the sensor and just move it away (this is how I did it) but not 100% sure that this doesnt damage the sensor.
Edited by 89CAL
  • 7 months later...
Does anyone know if the Hitachi CAS is a direct swap to the Mitsubishi CAS?
I bought a second hand Mitsubishi CAS but the wiring plug is different between the two CAS units. If the wiring pin out is the same i'm thinking about sourcing a plug to rewire the loom to try the Mitsubishi CAS. Plus side would be that you can still buy the Mitsubishi CAS brand new but not the Hitachi.
No they are not. Wiring is least of your problems - wiring needs to be reversed but the drive on the end of the camshaft is different.
I'll have to get a Photo of the 2 different CAS i have, both are for the r33 RB25 not the NEO. both have the same shaft that goes into the camshaft.
Just looking at the CAS one has the Mitsubishi logo visible the other does no just a solid metal case.
Did a quick search and found one that i have on my car (1995 R33 S1.5 RB25DET) 104_0638-1.jpg
This is the Mitsubishi CAS that has a different plug to the one above IMG_0405.jpg
I ended up buying a new one at the time because I needed good signals for and aftermarket brain . People tell me that these CAS units go off over time and most original ones won't be at their best . Lots of heat cycles and bearings wear over time .
New can be expensive but probably the simplest and best result .
A .
Those are both Mitsubishi CAS and the plug should fit both. I have had both on my car
This is a Hitachi CAS:
Genuine-Nissan-Cam-Crank-Angle-Sensor-23
If the 2 CAS' you have pictured are in any way different, one will be an RB25 CAS and one would possibly be a CA18 CAS
  • Like 1
Now i'm confused, i bought a R33 RB25DET CAS of Ebay ( and it is the Mitsubishi logo one but is a diffrent plug.. did CA18s come out with the Mitsubishi ones? im thinking the one from ebay might not be a true rb25 cas but did come with the engine bracket that the cas bolts onto under the timing belt cover which is defiantly for rb25.
Ill get some photos tomorrow if someone could help and confirm if i have the same plug or a different CAS plug.
Dont have the tools to open it, has tamper safe screws.
1377300246139.jpg my current one is on the left.
That's a shame as the r34 cas (hitachi)has two Philips heads screws
Edited by StevenCJR31
Thanks for confirming, now to see if i can get my money back via PayPal as it was advertised as a RB25 turbo CAS.
Is Kudos Motorsport the cheapest place to buy a CAS brand new? currently $660 http://www.kudosmotorsports.com/catalog/nissan-cam-crank-angle-sensor-cas-genuine-nissan-skyline-r32-gtr-gtst-gts4-gts25-r33-gtr-gts25t-gts4-p-1176.html
The one on the left is an rb25 one. Not sure what the one on the right is off. Z32 or CA18 I guess?
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
    • This is going to be a mid week evening cruise. Come along and join us for a drive out to Palm Beach. This is a change of event plans after talking to some of the older members of the club. SAU NSW is planning on hitting Old Pac again shortly, stay tuned for details. When: Thursday 26th of June Time: 7:30pm meet/8:00pm departure/10:00pm finish Meet: Spit West Car Park / Spit Rd Mosman NSW 2088 Destination: Palm Beach Public Parking / 16 Ocean Rd Palm Beach NSW 2108 Up to date information as always can be found on the events page of our website, the link for this event is https://www.saunsw.com.au/events/palm-beach-cruise There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Good time for a carbon roof
    • Not in any way aroused by any of those, except maybe the big AMGs. And that would break my never a Euro, ever, rule.
