Hi Guys, my r33 is in need of a proper clean including a good cut n polish etc as there are some marks on the paint ever since those buggers at Jack Hillermans repaired it from an accident 18 months ago. Whilst they did a good job on the repair, they left marks all over the car seemingly from where they had taped plastic around it... I don't drive the car much so didn't cotton into it until later. Its hard to explain these marks but they annoy me when i see the sun reflect off them. I dunno if it stripped the clear coat, stained, something that's visible when light reflects off it. They are mostly around the door handles and rear bumper. Anyway, im after someone who can give the car a good solid clean and fix up this stuff as well. I don't want to waste a day stuffing around myself and potentially not even get the outcome I want. So options please.... either around the lower north shore (chatswood/st leonards etc) or Campbelltown areas. Thanks!
Not far from Chatswood at all is...
Eugene Chan (aka JDM_Performance) here on SAU.
He has polished/sealed/waxed several cars that have won awards.
0421.141.538 and he might be best engaged to spend a couple of days on your car.
You may be able to get away with it by cutting it yourself. I know you mentioned you don't want to spend a day stuffing around but it may be a simple thing. Have you got photos?
Also Terry, does Eugene have a website? I'm keen to have my cars swirl marks detailed. Being a dark coloured car, and having the right products, I just can't seem to get rid of them.
No website afaik, but I'll post up pics here real soon of my 2nd GTR - pearl black.
2 grades of Menzerna polish were used...
> swirls and scratches gone
> Bob Barker, Daily Telegraph photoshoot
> Best Concours M Skaife Award at R34 GTR 21st
+1 what Terry said.
I bought my car off a dealer where Eugene does the detail work before sale. I was very happy with his skills and attention to detail. Sadly now I have to learn myself - so off to the SAU NSW detailing workshop organised by Terry :)
With Bayside Blue...
Before...
After...
Eugene had changed his preference of Sealants from Zaino to Optima by this stage.
Hope this helps with your darker colour too Gary.
Thanks Terry. I'm thinking this product may help.
http://www.zainostore.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=Z-PC
Those look like amazing results. I'm sorry this is off the thread topic but how do you detail the bumpers? I always just wash and shammy it, nothing else.
I use Malco Banana Wax to remove black soot from the bumpers rather than polish because it won't abrade the sealant. Eventually though, maybe once a year, I'd go back to polish > sealant > wax sequence
    • Update 2: Today I'm f**king pissed. Some of you probably saw my thread that I opened shortly after joining this forum, "urgently need expert/experienced opinion", in which I discussed the possibility of a porous RB26 engine block which I also found hard to believe. Currently both turbos are out since the shitty braided line that was installed by whoever fitted the GT28 turbos leaked oil onto the exhaust. Today while working on the cam covers to put new gaskets and half moons in, I cleaned the side of the engine block with brake cleaner. Some time later I saw that it was still glistening with oil or coolant so I dried that off. But it was wet again shortly after. Verdict: I'm royally screwed. What you can see here (hopefully, despite shit resolution), circled in red, is a crack above the turbo oil feed. Extent is a few cm long and basically goes from #3 cylinder wall to #4 cylinder wall. It slowly lets coolant through, even without any pressure behind it. I am absolutely dumbfounded as to how this crack even formed, especially since it isn't along the cylinder as it usually is but rather a horizontal crack. Probably a few cm in length. Not sure on how to deal with this issue right now. Most likely, the only true fix is a new engine block, and even a relatively well done temporary fix requires at least a full engine teardown. Neither of those really fit my timetable right now, the car has been in my buddy's garage long enough as it is. I'm open to suggestions, but I'll be looking into ordering a new 05U block soon so I have one ready for the coming year, or whenever the current block inevitably fails fully. (Most likely once the crack reaches one of the frost plugs) I think it'd be a waste of money and time to rebuild the engine with this block. Oh and I found a rust hole on the side pocket of the trunk, which someone covered up with sealant goop, a piece of number plate and bodywork filler. Fun times. So far for every issue we fix we just find a new one that is arguably worse.
    • I have not found this no. I put one back on a couple days ago with no drama. I agree they are tight, but no need to remove anything.
    • That is gates blue racing belt
    • Anyone found gates blue racing to be extremely tight/ almost impossible to install without moving the exhaust gear
    • Hello am apex am new here and also thanks for helping registering the forum
