Hey Guys
I just wanted to get some opinions please:
I just got some headers and HFC's and from what I've read, installing both of them would mean my V35 would be running very lean? ( My mods so far are: drop in K&N filter, Z Tube, TDX2 exhaust)
So I was planning on waiting to save up some more pennies, get the headers and HFC's installed then get it tuned ASAP at east coast customs in Brissy with the UP Rev software, so I may not damage the engine.
Am I being a bit too over the top about having to get a tune straight away? My V35 is my DD so it gets driven very often.
I would say doing an ECU reset would be enough to sort out any leaning issues. Its not like your slapping a super/turbo charger on the car thats going to boosting a significant amount of extra air through the engine requiring a significant amount of extra fuel to be added to the mixture
hmmm interesting, thanks for your reply guys. Looks like I may just get them installed without a tune then just a reset :)
What else gets reset with a 'ECU reset' though?
I believe Glen's ECU is in Texas because
Thats complicated! First run was 166rwkw without a tune.
My ECU didn't seem to like Uprev; it had a Master rom version they hadn't seen before so its with Uprev to get it sorted.
Only thing that gets reset is the learned fuel settings. And the dtc codes.
I would be asking serious questions why ecu is in Texas. I have been down the new map path twice with uprev, both completed successfully without the ecu leaving the car. Was my car, pnm35 and a adm pathfinder.
My bet is that they tried to flash a file onto the car from a different ecu and bricked it. Now they are trying to recover it. Hope your not paying for it.
Yep PN-Mad you got it in one. They have been really good about it trying to source another ECU (difficult because its a manual), and got it sent off to Uprev ASAP.
They are sorting it out at no extra charge to me, so I'll let you guys know how it goes. I've been happy so far with the way they have dealt with it; by being upfront and honest about it and trying to do what they can.
Luckily I've got a motorbike as well!
Good to knowthey are sorting it out. Hope it works out for you quickly and effectively.
Frustrating when they just had to take 2.5 hrs to dump the rom, send it off to uprev, and in about 3-5 days you'd have it back cracked and coded.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
