hi mates. just wondering if my idea will work.
have a rb20det in r32. thinkn if i get a rb25 head and weld the front hole so it joins up properly to the block and put the rb20 cams and sensors and cam gears and everything like powersteering alt etc on to make a 25-30. so i can use the rb20 ecu and not have to do any wiring changes and not worry bout vct etc.
will that work?
thinkn just a safc to fix it up abit using the vg30 turbo and everything currently on the 20. maybe bigger injectors
thats an option but they not too common to buy.
what im thinking is that i will need to get the rb25 head resurfaced so gotta pull it apart anyway so was thinkin il put the rb20 stuff in when that gets done so no extra expense there. the hole will cost little to no money to get welded at that time also so its not any stuffing around.
some bigger injectors and probably will go nistune after all for that side of things. just wanna know if my head combo will work etc. coz ive been reading people put rb20 cam on the vct cam to remove it. if i rb25de r32 head was to pop up id go it for sure but they have problems with valve float or something apparently so gotta spend a few hundred for springs if i go that route also.
so wanna know if itl work? maybe im silly but
if you use the R32 RB25DE head then you will need to use the matching intake manifold
1000cc bigger capacity. Head is way bigger. By time you stuffed around you could of done it properly.
Just get a R32 RB25DE head
what about the 26 head? do all the water and oil holes line up with the 30 bottom end?
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
