hi mates. just wondering if my idea will work.
have a rb20det in r32. thinkn if i get a rb25 head and weld the front hole so it joins up properly to the block and put the rb20 cams and sensors and cam gears and everything like powersteering alt etc on to make a 25-30. so i can use the rb20 ecu and not have to do any wiring changes and not worry bout vct etc.
will that work?
thinkn just a safc to fix it up abit using the vg30 turbo and everything currently on the 20. maybe bigger injectors
thats an option but they not too common to buy.
what im thinking is that i will need to get the rb25 head resurfaced so gotta pull it apart anyway so was thinkin il put the rb20 stuff in when that gets done so no extra expense there. the hole will cost little to no money to get welded at that time also so its not any stuffing around.
some bigger injectors and probably will go nistune after all for that side of things. just wanna know if my head combo will work etc. coz ive been reading people put rb20 cam on the vct cam to remove it. if i rb25de r32 head was to pop up id go it for sure but they have problems with valve float or something apparently so gotta spend a few hundred for springs if i go that route also.
so wanna know if itl work? maybe im silly but
if you use the R32 RB25DE head then you will need to use the matching intake manifold
1000cc bigger capacity. Head is way bigger. By time you stuffed around you could of done it properly.
Just get a R32 RB25DE head
what about the 26 head? do all the water and oil holes line up with the 30 bottom end?
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
