For sale Rb25/rb2530 full turbo setup.
.GT3582r .7 front cover with welded on elbow to suit. Tial rear housing .82 vband in and out ceramic coated.
.Custom steampipe low mount manifold, ported, merge collector,Vband outlet to suit tial rear housing. ceramic coated and heat wraped.
.Tial 44mm MV-R vband waistgate. 1 bar spring (14.7psi). With screamer.
The waistgate has been plumed into the tial rear housing on the turbo.
.3" Dump pipe from turbo to cat. Vband, custom made to suit turbo setup.
Not really willing to separate because everything has been made to work with the low mount setup.
$1850
.For sale rb25 head modified to suit rb30 bottom end galleries. Head has performance valve springs and Tomei 260 procams. Vct removed. Comes with rocker covers powder coated splatter black. And -10 breathers.
$850
might separate the cams for $400 ono if i can fined a buyer for the head $500.
also the head should still work on a rb25 but without vct.
Parts are at Samford (northside of brisbane)
Matt. 0423798425
Edited by Matthew Black
new pic of head removed. The Tomei cams are sold. it still comes with the performance valve springs and retainers lifters ect.. timing belt covers and cas bracket.
i can supply gtr cams and cam gears to suit. for extra $50
    • True, might get it looked at. Found out you can in fact flatten the 12v battery relatively easily too the other day (kids lefts the hazards on) so meaning to get that checked in the new year. What's odd is it'll blow cold from both vents if you have the ac down as low as poss (18), but anything else the passenger one blows warmish. Also has been summer since I got it obvs but noticed it didn't seem to want to blow hot last night when we had a cold snap.
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
