Hi fellas, these are off my s15, might find more interest on here given the size of the wheels
Specs: Fronts: 19x8.5 +23
Rears: 19x9.5 +27
Tyres: Hankook V12 245/35- fronts, Hankook V12 275/30-rears (only seen 1 full track day on these tyres and they are less than a year old, only drive the car as a weekend cruiser, plenty of meat and grip left on these)
Comes with original work lug nuts and center caps, s-chassis would require some work to get them fitted on, skylines should be okay i think (i could be wrong)
Reason for sale: need to downgrade to 18s
$2500 firm
0413 818 034
Item located: Northern suburbs of Melbourne
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
