Vl calais 1988 series 2 Turbo.
5speed manual(straight cut gearset)
Button clutch.
Fully rebuilt engine (done 14000km), gearbox and diff.
Large frount mount cooler.
Highflow turbo.
Full Whiteline suspension.
3 inch stainless steel exhaust from turbo to tailpipe.
Hsv brake set up.
Momo steering wheel.
Reclinable aftermarket front seats.
3 Autometre gauges custom mounted in the dash.
Blaupunkt 6 by 9s in parcel shelf
6 inch Kenwoods mounted in custom pods in front doors
Blaupunkt 4 channel amp.
4 Brand new tyres
17 inch VR clubsport rims.
Registered till may 2005.
Dark blue over silver.
$9800
Car is located in melbourne
[email protected]
0412 343 495 after 7pm on weekdays.
https://www.sau.com.au/forums/topic/41617-vl-calais/
    • Man, you guys are like an all knowing encyclopedia.. how do you guys know how to fix everything?? but thanks. i will try to trace this wiring today. What is this globe thing you are referring too? Globe Power Supply? Are you referring to the light bulb?
    • Vinyl paint always ends up coming off interior trim and looking like arse. For the a pillar trims.....just try cleaning them with fabric shampoo? Maybe ditto for the headliner.
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
