hi guys, got my stagea up for sale.
CAR: 1999 S2 Stagea RS4S Awd
Price: $14,000 ono
REG: December 2013
ODO: 100,xxx( ill update later with exact figures.
ROADY: not currently, but will supply for the right price.
i have owned this car for the past year, i am the 1st aussie owner of it. bought it with 84,000kms on it, its done 2 trips to sydney and back, reliable as they come. im seeling due to not driving it anymore, its been sitting here for over a month now, and i feel its a waste of a car.
MODS:
Full TAKEROS bodykit incl carbon firbe bonnet - i am yet to see another with a carbon bonnet, or even a full takeros kit in aus. kit incl bonnet $6k USD
HKS performer adjustable coilovers all round - no leaks and handles really well
Walbro 255l/h fuel pump. - currently on std wiring, but the car is wired ready for direct 12volt - its just not hooked to the pump
Cooling pro return flow FMIC
custom 3" stainless zaust - made in japan came on the car. its the only one i have seen with twin 4" mufflers out the back.
2 x Kakimoto Hyper Mega N1 mufflers
apexi BOV
HKS pod filter
turbosmart dualstage boost controller
2 x 10" pioneer subs
eclipse AVN-076HD - this is a good dvd/gps headunit, except its japanese haha, cannot get an aussie conversion for it, but still works well.
2 x digital tv antennas - i dont use them, but they are there.
5.1 surround dolby digital decoder also eclispe.
4 x clarion 3-way speaker in the doors - installed in japan.
late 2011 Alpine PDX 600.1 monoblock - this is running my 2 10"s @ 2 ohms. - custom installed with lights n stuff, will get pics later
19" Koya Endless rims in black on it with chrome inserts(taken out)
Falken FK452's 245x35x19 - near new - less than 1000kms also had camber/steeing alignment done at the same time - front and rear.
the car will also come with a full set of SARD 650cc injectors to suit. they have been used but arind in good condition. rrp $1500 a set new.
i had big plans for the car, but i just dont have the time or the money. there is a little bit of damage to the body kit, the bonnet needs to be re-cleared, one of the front guards got pulled by the front tyre and the tensioner pulley need replacing soon as it has recently started to knock, apart from that, the car has nothing to be done. i also have a can of matched touchup paint that will come with it.
i will post a full set of pics later today, inside and out, incl damage etc
Edited by OMY31T
https://www.sau.com.au/forums/topic/416203-c34-rs4s-stagea/
  • 4 weeks later...
update:
bonnet is being re-cleared, front bar damage getting repaired, and a nismo timingbelt/waterpump/idler and tensioner pulleys goling into the car. nothing more to spend.
rego until dec 2013, i might consider a swap, im looking for a V8 commodore, VX clubsport or somthing similar, need a tow car for my boat.
https://www.sau.com.au/forums/topic/416203-c34-rs4s-stagea/#findComment-6728366
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
