Cheers Disco, I do appreciate the newer car vibe. For myself I actually have an S14 and am nearly finished with the setup. The sigma is sort of a side project for me, mainly my brothers with some help from myself. Realistically if I dont participate nothing will ever get done.
Looking under the bonnet and seeing the manifold etc really does make me sympathetic to the old astron lol, a lot of time and effort has gone into this setup and it would be a shame to give up on it. The money to date is also a major factor for me to try harder. I wont say how much has been spent to date, but it is a lot.
Just to be clear would LSA need to be a higher or smaller number? I will put my feelers out for a factory cam, brother wont like that but it may get us somewhere. Ill also try to track down a larger housing for the GT30.
  • Replies 53
higher=less overlap
not sure how mnay cams you've changed in sohc motors disco..but that reaks of problems
with turbo cam 10+yrs ago..things have changed a lot since then and cam makers have cottoned on what a
engine needs a lot better...we aren't getting old blower grinds anymore with large overlap that blow all the energy out the ass end. I think all the problems you mentioned come back to to lsa actually..
I've had people sell me blower grinds that where shocking 10+yrs ago when asking for turbo cams, and yes all those
problems existed, but the grinds these days are alot different.
Even a basic stage one cam with a 114lsa would outperform a "standard" cam in every way usually, theres more to cams
than just duration and lift, the way the cam is designed in regards to the lobe shape has a big effect on drivability,
Even going back to sohc cam rb30's, the tighe cams are quick lift cams, they run much more lift and duration than stock..but still make more bottom end and midrange torque than the stock cam and spool a turbo quicker...and make another 30-40rwkw..lol
twin cam stuff is a different kettle of fish again, and the designs are much more recent..
personally if i only had the choice of one , i'll take duration over lift any day of the week with a turbo car..providing i can change the LSA
cheers
darren
Edited by jet_r31
Jase has the car been tuned on both cams or only one? And if 1 which 1?
Maybe bring it up one day and i'll spend an hour on it too see if the ignition timing is tuned correctly by the last tuner
Cheers Jez ill probably take you up on that hour. Would be good to get a cost effective second opinion on the tune also. As stated I think its OK but then again im no tuner. Have you got software for an EMS stinger?
As for the cam it was originally tuned for the smaller cam and then was touched up with the larger. Not a great deal of time was spent on the larger but I dont think there was much left in it anyhow. An hour on your dyno will tell us A LOT though.
Darren im thinking ill force him back to the first cam which is a stage 2, has 230* @ .50 and 114* LSA. Do you think that cam is significantly better suited or think I am wasting my time?
I'll also see about getting a housing, maybe track down the supplier of the ones Scotty mentioned or see if Stao can make me one. Would you be more inclined to test a .82 or 1.06? My gut feel is saying go the 1.06
Id personally go back to the first cam for testing, as to me it takes one thing out of the equation, as in "theory" that one should
work fine with that setup. If you do fix the problem and its something else, then you can refit it later and re test it.
out of interest, what type of cooler is fitted?, much pressure drop?, and what valve springs? especially with big cam?
close to coil bind?, its not getting valve float from boost pressure?
The big one is something i would fit if a mate said i want a 2.6 turbo and i want to turn the world on its axis.
And even though i am no astron expert i'd spec that with a 116 LSA and a PT6466 with plenty of boost shoved up its ass.....lol
This is why i like old motors turboed and like working on them , yes they are a pain in the ass, but f**k me at least you have to
think and work some stuff out for yourself, much better satisfaction than buying most newer motors, any idiot can
get a good result out of a Rb25 etc..lol
cheers
darren
Edited by jet_r31
I woudn't take that to heart..lol, but look at how much more info there is out there for newer motors, its like building a oversized model kit
most of the time..cars being cars, its not always going to be smooth sailing for some unlucky ones..but thats just cars in general
thats why love and hate them at the same time!
cheers
darren
Edited by jet_r31
Haha nah you're right mate, I can have a laugh at my expense :laugh:
OT, I don't have anything useful to input, but I've been following the thread with interest. Keen to see how you go Scott!
The cooler is a china 450x300 (shorter variant to the generic 600x300). Was purch back in the day from JJ, quality seems fine and no issues. Cooler piping is 2.5" from outlet to throttle. Throttle is a little small but dont think that would hold it back that much. Not any smaller than an S14 VCT throttle body from memory.
Valve springs are actually the matching item for the cam. They were purchased as a set from camtech. Im gonna try get that smaller cam back in ASAP, need to beat bro to pulling the motor as hes wanting to rebuild the motor (not that it will help). Im wanting to find the problem and then retune on a fresh motor.
Cheers for the input guys, I'll find some time to pay Jez a visit soon and see what he and his dyno have to say. Hopefully a feeble issue can be found and sorted or at least the bigger issue will rear its ugly head.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
