Hi guys,
My previous car had a custom dash so I've changed this over into my GTR, so I have for sale a standard GTR dashboard.
Also have R33 GTR Bonnet hinges and bonnet latch as I was going to put GTR bonnet on my previous car.
Bonnet Latches & Horns: $75
Dashboard: $80 (Does not include the surrounding for cluster/centre console etc...just the dashboard.
Bonnet Hinges: $50
H1 HID Kit to fit R33, used 8k headlights really good for night driving. My new car already had HIDs in them so dont need these anymore. $50 for all ballasts and globes, usually $120 for the kit.
Or PM any offers, located Melb Sth-east suburbs
Cheers
Dan
R33 GTR Bonnet/Bonnet Latch/Bonnet Hinges great deal if someone is doing GTR front conversion on a GTST. $300 for the set.
The dash is in perfect condition, only swapped due to my dash already being retrimmed in my previous 33. $60
HIDs great upgrade especially for those who drive at night, big difference. $50
  • 3 weeks later...
Bonnet Hinges and Latch SOLD
HID Kit SOLD
Dashboard and Glovebox + Under steering column panel still available. From 1996 R33 GTR.
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
