CRZY32 Posted December 26, 2012 Share Posted December 26, 2012 I'm hoping someone here has more sense than me and can help diagnose this strange problem. Driving home from a hard day at the track on a hot day, the car developed a splutter and would hardly boost at all. The engine revved freely but the turbos felt like they were choking and boost was limited to max 0-2psi. Boost has always been set to 17psi and previously holds steady. Factory boost controller. Knock levels are low always under 35. The next day the car was over boosting to 20psi, greater than the set limit of the modified actuators. After about 10 minutes of driving, the flutter started and the car felt like it was choking again. But retained boost, fluctuating around 15-20psi. I've visually checked most hoses and pipes but there's no obvious splits or loose joins. I've also cleaned the AFMs with contact spray. I'm guessing it might be waste gate actuator related and then the power FC is going into limp mode? Link to comment https://www.sau.com.au/forums/topic/416236-help-needed-with-boost-spluttering/ Share on other sites More sharing options...
CRZY32 Posted December 31, 2012 Author Share Posted December 31, 2012 Does the Apexi Power FC display factory fault codes? If yes, how do I initiate the diagnosis mode? Link to comment https://www.sau.com.au/forums/topic/416236-help-needed-with-boost-spluttering/#findComment-6686133 Share on other sites More sharing options...
XKLABA Posted December 31, 2012 Share Posted December 31, 2012 I had a similar thing happen to me, when car warmed up I would lose boost, leave car to cool off and boost would return, ended up being the cat was stuffed changed it to a new high flow and problem never came back Link to comment https://www.sau.com.au/forums/topic/416236-help-needed-with-boost-spluttering/#findComment-6686152 Share on other sites More sharing options...
paulr33 Posted December 31, 2012 Share Posted December 31, 2012 the pfc displays the standard errors and will turn on the check engine light or exhaust temp light on BNR32 you can look at etc, sensor sw check to look for any sensors with black highlight, this means a sensor has failed it wont be a sensor failed causing your issue it sounds like hot / melted vac lines or something simple Link to comment https://www.sau.com.au/forums/topic/416236-help-needed-with-boost-spluttering/#findComment-6686156 Share on other sites More sharing options...
CRZY32 Posted January 5, 2013 Author Share Posted January 5, 2013 the pfc displays the standard errors and will turn on the check engine light or exhaust temp light on BNR32 you can look at etc, sensor sw check to look for any sensors with black highlight, this means a sensor has failed Checked the Power FC display and the following sensors where highlighted: IGN - ignition IDL - idle ECC - ? F/P - fuel pump O2H - O2 sensor setter? I'm unsure as to what these are and if they might be causing the issue.. Any ideas? Link to comment https://www.sau.com.au/forums/topic/416236-help-needed-with-boost-spluttering/#findComment-6692728 Share on other sites More sharing options...
