I have owned this R33 for around 2 years now but it spent most of the time parked in the driveway as I had my white R34 “GTNAH” and thought I can build the R33 to be my thrasher/Track car at the same time. The project started sometime last year working with my brother but here is a run down of the events that took place.
The R33 started something like this:
Unregistered
1995 RB25det
R34 Neo turbo
Front mount
3” Exhaust
HD clutch
Lowered springs
Stock wheels
Genuine Impul skirts and rear bumper
Stock look - Test fitting my R34 wheels (Rota P45 R2 18x10 +12)
The plan was to keep it simple but for most projects things don’t always go according to plan. So a BN kit was sourced and due to the poor status of the paint, it had to be sorted. That's when it was sanded down and prepared for a respray.
post-43096-0-81583700-1356559429_thumb.jpgpost-43096-0-00388500-1356559583_thumb.jpgpost-43096-0-71656600-1356561432_thumb.jpg
In the means time, a set of Tein coilovers and 18” XXR wheels were installed along with an aftermarket bonnet and the end result was something like this.
post-43096-0-45833600-1356559913_thumb.jpegpost-43096-0-25032700-1356559949_thumb.jpegpost-43096-0-15298900-1356559975_thumb.jpgpost-43096-0-49197500-1356561250_thumb.jpgpost-43096-0-46652800-1356561799_thumb.jpgpost-43096-0-55457800-1356561819_thumb.jpg
At this stage I needed a daily and knowing non of the pits in perth would pass the car as it is, it had to be altered to be more street friendly so after a few minor adjustments and a couple of trips to pits, it was registered and officially street legal.
post-43096-0-62112900-1356560583_thumb.jpgpost-43096-0-79904000-1356560614_thumb.jpgpost-43096-0-74899600-1356560632_thumb.jpg
The plan now is to install some of the a few bolt on mods that I have to get the car back to its original plan which was track days with the ability to use it as my daily.
KKR480 Turbo
Wolf 3D ECU
External wastegate
Change fluids (box,diff)
Change thermostat and Fuel filter
Boost controller
Upgrade Coilpacks
Apexi ECV
Upgrade fuel pump
Alloy Radiator
Nardi Steering Wheel
GTR seats
GTR front bumper
GTR bonnet
There is always a chance of more unpredictable changes while its getting ready for a decent respray but for now the GTR bonnet / bumper seem like the ideal options since I have already have the parts
Feel free to make any suggestions
https://www.sau.com.au/forums/topic/416259-r33-the-untold-story-starts-here/
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
