hi all
i am looking at getting an RB20DET for my skyline R31...
At The Moment i just have a Couple of Quick Question..
does the RB20DET loom bolt Str8 up into the existing rb30 loom spot and computer??
Do you need to run an after market ignition System, like microtech or something like that?
Does the Rb20DET bolt straight up to the standard rb30 engine mounts?
Is it worth having an LSD or is standard Single Spinner Diff Good?
Do the Standard Brakes Stop it? or is it worth upgrading them??
but something has got me stumped here, How do you start the things when they run coils and transistor unit? can i adapt the rb30 ignition loom into it or something like that?
Does the Fuel Pump Need upgrading??
Thanks for you help all...
https://www.sau.com.au/forums/topic/41627-info-on-r31-with-rb20det/
You are probably best off getting a front-cut, where you will get the engine and a loom & ECU. Otherwise, you will require an aftermmarket system. There is no way the R31 ECU will run a RB20 - as you pointed out, the RB20 runs multiple coils (triggered by a CAS), while the RB30 runs a distributor.
The RB20 will slot straight in on the R31 mounts.
yea i know that but i can get an RB20DET Eccs out of an R32 with a LOOM and computer, and im wondering if i wire that all up and put the computer in the spot where the rb30e computer goes, how is it going to fire off the coils and stuff, because i dont really want to get an Aftermarket Computer and wiring loom for it because i wanna keep it a simple project...
If you get a RB20DET loom and ECU, they will have everything required to run the engine, including working the ignition system. All you need to do is pull out the RB30 ECU and loom, and replace it with the RB20 ECU and loom. I'm guessing the RB20 ECU will mount in the same spot as the RB30's (that's where the RB20 mounts - behind the passenger kick panel).
yea it does but, how can i run the aussie dash with the rb20det ? like temp gauge and oil pressure gauges in the aussie dash? also would i use a R32 Starter motor loom and adapt it to the battery so i can start the rb20det??
Starter motor loom??
You basically are using the RB20DET engine loom (start motor would be off that i assume), the RB20DET ECU, and from that you splice into the dash loom to get your little gizmos working. But most of that stuff is separate to all the engine sensors and that sort of thing.
All your coil firing and ignition stuff will be controlled from the RB20DET ECU, so don't stress about that side of things.
Some adaptions need to be made also, i believe for the fuel pump system, and other bits and pieces such as the guages, speedo, tacho, etc.
Anyhow, I will admit I am just going from what I have read, not done. Bozz knows all.. In fact just bolt it in and pay him $500 or whatever he charges to wire it up for you :)
Apparently not massive difference between stopping power of R31 and R32 brakes, so not required to be changed for engineering in many states.
LSD would be nice.. you're going to have troubles with the single spinner and feeding power through it to the ground on takeoff. A diff specialist told me the borg warner *should* be strong enough in terms of holding out (e.g. not go cactus), but LSD would be better. The single spinner should handle the power and stay alive for a while, if you don't do massive burnouts, take it a bit easier right off the line, and crap like that.
and before you ask.. no you can't fit an LSD from any import model skyline in. You'll have to get an aussie B/W LSD that fits the housing.. can be hard to find these days. Expect to pay around $1k to go to an LSD.
All turbo R31's had bigger brakes factory standard, and in Victoria a brake upgrade is required for an engineers certificate.
hey mate, i just finished doing the saame conversion about 4 weeks ago, these guys pretty much covered it, you will need to pull the temp sender out of the rb30 and putit into the rb20det, and same with the speed sensor that screws into the side of the gearbox. as for the tacho, you need to run a seperate 12v inpput onto the line with a 10kohm .5 watt resistor between the 12v and tacho signal wire. beasides that i used the alternator air con pumps off the rb30, they bolt straight on, its all pretty much bolt straight on stuff, also your turbo dump wont exactly fit you zorst so u may need a custom peice made up, i used a rb25 zorst between turbo and cat and it fit really well. besaides that its pretty easy. good luck, any other quest, let me know.
ahh ok, i currently have got turbo Import brakes on my R31 atm which would probably be good for the turbo conversion, although i dont think i would run powersteering because the racks always leak oil out (trw), but yea i can easily get that zorst system made up... i think id buy another clean skyline and work an rb20det into that one...
thanks for you help all....
i sent u a pm, make saure to check it
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
