Auto drop won't drop very far so the function is kinda pointless on my v35 and wen I put the window Down as soon as I press the button it's drops about an inch really quick with a horrid click sound n continues to go down as normal
Can anyone help me ?
https://www.sau.com.au/forums/topic/416313-v35-power-windows/
Oh so does that mean the motor has developed some kind of free play?
I got my partner to adjust the window it now drops ok but still with the horrid click.
Wot is actually making the click sound
does your driver side window and passenger side window both go up and down at the same speed? or is 1 slower than the other?
this is a very common problem with these cars, usually the motor generates alot of gunk and dirt inside the motor usually around the brushes. There is a DIY to clean them but usually the problem just comes back later so best to solve the issue right the first time.
BUT, in saying that i'm not sure if that problem is caused by the gunk and shit building up by the motor. I would PM Chris Rogers or wait til he replies here usually he chimes in on these topics regarding the power windows
From images I have seen online, the motor seems well closed off, so I would say all the "generated gunk" you see is basically bits that were once part of the motor itself... this of course is coming from someone who appears to have "solved" their window problems with a mild bang on the outside of the door with his hand. :wacko: twice...
Thanks guys for the support.
So wot is making the loud click sound it sounds like something is hitting the window itself and why is it dropping quickly in the first instant?
Do the cables stretch?
And the the 2 bottom threads that screw into the bottom of the window tracks with the flat blade slot in the end of them that hold the tracks to the silver plate that bolts the main part of the door?
How do I know how much to screw them in or out?
why are you touching them in the first place? that it the main adjustment for the angle of the glass. keep screwing with it and you will be up for a regulator as well. leave it alone.
They wer all loose n there was clear signs they had been tampered with/adjusted preiviously,kind of sucks but we will work thru it.
Do u know where they should be?
I don't mind buying a new regulator if it means everything will be spot on.
Do u know why it's dropping really quick for just the first part and making the horrible click sound/wot is physically making the sound.
So Chris can you just let me know what exactly the Regulator does? Need to know because if i replace my window motors i would like to be sure that it would solve my "auto" up and down feature of my drivers side because that's stopped working
graphite grease.
regulator is what holds and moves the glass in place. if all you have done is drop the 4 bolts holding it on then fine. if you have taken the 4 bolts off AND moved tbe bolt position then i cannot help you as i need the car un front of me. either way you need two motors at best. do the locks whilst you are there as those will fail next.
    • God I love shiny engine parts 🥰 Are you looking for more horsetorques in the mid range? (Smaller cam) Or just more horsetorques every where? (Big heads and bigger revs) Assumption: they were not bought late night shopping on the interwebs after drinking too many beers, which is typically how I pull pins on things......🤣 The evolution of your car is coming along nicely, I sometimes wish I didn't get bored with my cars and keep flipping them, maybe the MX5 will be different
    • I got the hazards working! Turned out it was disconnected! Indicator stock still isn’t working. I took the steering shroud off and there seems to be a third connection missing I see two small white connectors but they don’t fit the indicator switch unless they need a short lead to convert the connector type. Can someone point me in the direction of the wiring diagram for the indicator switch?   https://share.icloud.com/photos/0e8ReiFSLBVJsTPUKKfA_1IdQ
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
