Does anyone know of any fabricators who do custom wing support extensions for a 33 Gtr oem wing. Or anything similar?
Regards
Yes , example please
Do you want to go up or out or ?
carbon /kevlar/ glass /zylon
I'm want to go up slightly, kind of like the 34 gtr extensions. although something that i can simply bolt onto standard wing to raise for more downforce. Not sure on material maybe carbon fibre supports something simple and affective. Cheers
Which wing do you have now?
Yes taller is not a big deal
Yeah those extensions look sweet maybe abit shorter? Troy I have oem wing, do you make these things?
Can make anything ( except large parts like bonnets etc)
I would need some side shots of that style or hand drawing side on , a close up of the front side
and a tracing of your wing profile and upright profile to mock up a test version
please note a sharp plane holding up the wing works but the police will ask you to remove it for pedestrian safety ( by the time someone gets that far its bad anyway geez) so a little shape would be required to round off the blades slightly
Aerodynamics would improve anyway and it would be stronger as well
So if someone can do that I can whip up a test part for someone to fit up ? I know a local with r33 gtr wing but doubt he would consider using his car to test fit on , so need someone else
I could be interested in this too depending on price. Maybe if there's enough interest we could arrange a GB?
Bit soon for a GB lol
Gotta get a set made first to figure out time and materials
If I had a gtr boot with spoiler on my desk it would be done in a week or less , any spare floating around Adelaide ?
( yes I need to move from SAdelaide to QLD to have access to more club users haha)
Haha fair call. Just getting pretty excited about the prospect of this haha :D
I think psi parts already sell one..looks better than that too
Dont see one on there site ? I'm sure a bunch are around but at what cost ?
None are kevlar encased , that will help keep it from shatering , most are just flat plate carbon cnc cut and screwed on ? I know a few people who had the police ask them to remove the sharp blades on wings or remove the wing
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
