Something was said about bee*R making one I believe...
The hyperrev books have a few suppliers of those
But the book is old now who knows if they still do or if they have any left
Anyway you guys sort it out. Hit me up if you get stuck
Ive searched and cant find any, the beeR one is a double wing and is a bit wider than oem, i have a std gtr wing blade in the garage if that helps for measurements or design....
Who's car is in the photo? Maybe they can help with skme more info?
Dont see one on there site ? I'm sure a bunch are around but at what cost ?
None are kevlar encased , that will help keep it from shatering , most are just flat plate carbon cnc cut and screwed on ? I know a few people who had the police ask them to remove the sharp blades on wings or remove the wing
i think it was PSI I may be wrong....theres one on Richos racecar ..you are right it does stick out a fair bit though..
but you have to admit its a better looking unit..
That's the bee-r rear wing. A few places sell replicas of those now at good prices, it's probably the best looking aftermarket rear wing for n r33
The beeR spoiler is about $600, im sure an extension part for the oem would be a heap cheaper, thats the best part, though i have been tempted to just buy the beeR over the last 24hrs of searching for the best pricing for it...
Honestly, unless it's for performance enhnacing reasons - I wouldn't recommend it - besides the fact that it doesn't look crash hot, visability will be limited from the rear too! I had a GT wing on my GTST previously and visibility sucked.
if anything i rekon rear visibility would be a heap better. the standard gtr wing sits pretty much smack bang in the middle of the rear window even at the lowest angle of attack
That looks way better !!
The downforce is better I bet its a modern airfoil shape wider both ways and still gets up into clean air off the roof ( bet the vortex is right off the roof into it)
I have that wing in my closet just not the same stands
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
