few things to clear out
R32 GTS4 Front Diff 4.375
ring and pinion in excellent condition
$350 pickup western sydney or postage at buyers expense
R32 GTR Dump pipes
no longer needed as upgraded to aftermarket dumps
$20 pickup only western sydney
Rb26 Airflow Meters
pair of R32 GTR afms thats no longer needed
been sitting in the shed for past year as i had upgraded to nismo's
$50 for one or $80 for both pickup, postage at buyers expense
Tomei Metal Intake Manifold Gasket (new)
same as this: http://justjap.com/s...&cat=318&page=2
$100 pickup or postage at buyers expense
R33 GTST Black Front Grill (new)
brand new black R33 grill with all clips
$100 pick up or postage at buyers expense
R32 Hicas Bar (new)
black in colour, never fitted
$60 pickup only western sydney
Alpine Type-R Splits 6.5"
recently removed from my car, surplus to requirements
comes with x-over box, woofer and tweeters
has a small crease on the woofer from hitting door speaker trim hence the cheap price
Fibreglass R32 GTR Wing
was painted gunmetal however not factory KH2 colour, paint in good nick, but few small cracks
$80 pickup only western sydney
Secondary Bonnet Restraint
required at CAMS drift events, and circuit events
Designed for stock bonnets/latches, easy and clean alternative compared to bonnet pins.
approximately 30cm long, still enables bonnet to be partially opened for extinguisher access
features covering over the whole cable, and ends, to protect paintwork
stainless hardware
high strength 7x7 multi strand stainless cable.
comes with a free battery triangle sticker.
$35 posted or $30 pickup western sydney
R32 GTR Stock Airbox
changed to pod filter setup and hasnt been used for a few years, all clips intact etc, in decent condition, no air filter included
good setup to avoid heat soak from the engine and clearing defects
$150 pickup western sydney or postage at buyers expense
R32 Centre Console Trim (not the one around the radio/gauges)
$30 pickup only western sydney
R32 GTR Bootlid
gunmetal colour but not factory KH2
has a small bent edge below the badge
$70 pickup only western sydney
Apexi EL2 Boost Gauge + Control Box
white-faced electronic gauge, comes with wiring loom, works fine except doesnt light up at night
never bothered looking at why as i had another spare boost gauge which i installed
$60 pickup western sydney or postage at buyers expense
R32 GTR Castor Rods
has offset bushes installed
$50 pickup or postage at buyers expense
pm me
Edited by BWRGTR
https://www.sau.com.au/forums/topic/416331-shed-cleanout/
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
