Unless otherwise stated, all items are 732 Nissan Black Metallic.
Item 1: R32GTR Nismo ORIGINAL side skirts - without front guard 'cap' section. Use your standard one; they're the same.
Condition: Very good, but needs repaint. May need to bolt as well as sikaflex onto rear guard
Price: $500.
Postage: No, pick up only inner North, Melbourne
Contact: PM me
Pics: as below.
Item 2: R32GTR Nismo replica bonnet lip, fibreglass
Condition: Excellent, does not need repaint. Attaches via double sided tape and 4 screws.
Price: $120 or offer.
Contact: PM me
Pics: as below.
Item 3: R32GTR original factory side skirts in SILVER.
Condition: Good, but needs repaint.
Contact: PM me
Pics: as below.
Item 4: Factory R32GTR bootlid
Price: $100 or offer.
Contact: PM me
Pics: as below.
Item 5: R32GTR driver's side mirror.
Condition: Very good, does not need repaint. All motors worked when removed.
Price: $50 or offers.
Contact: PM me
Pics: as below.
Hi, I'm very interested in the r32 Gtr n1 Nismo side skirts. I would like to know if there's anything broken/repaired ?? ( other than small scratches )
If you say that everything is ok and there's no major damage with the skirts like ripped screw holes in the plastic , I'll take them .
I can send you payment on the 10th jan via PayPal .
Send me your PayPal address.
Thanks
Gabriel
Mirror SOLD
Nismo skirts PENDING transfer
Roy: if you want to dummy fit them to the side of your thing message me and come over we can hold them up to see if they fit...
Keen to but the prob is of course it means I have to remove the skirts currently one the car, complete with double sided tape etc etc which is a head fark to get back on properly
:thumbsup:
Will be putting the new vents in my Dash when it arrives. Before putting it in the car.:)
Going to be a nightmare pulling my existing one out from what I've heard. A lot of this maybe :rant:
  On 01/01/2013 at 6:26 AM, Frosty said:
Will fit without too many issues at all ROY
not if Roy has anything to do with it ;)
    • I'm going to run hard lines front to back in the future. That should help dissipate a bit more heat. If not, a fuel cooler might be next
    • No. The mark is with respect to the cam rotation. None of those things have altered it. When stationary, the cam position stays in sync with the crank position. It doesn't matter if you moved the head 4 feet up. Hence, that mark needs to stay exactly where it is.
    • Toasty! I was around the same. Around 50 but with a fuel cooler. Got my tuner to dial down the pumps and its so much better.. i think last time I drove it was around 35-40 during summer. PWM makes a huge diff. I have the 1 PWM controller running my feeds.
    • Driving around town in summer, probably like 50°C tops. Went for a 2 hour drive before in summer, somewhere in the 60°C Mind you, I have 3x fuel pumps. 2x 460L 1x DW200
    • Good advice, I’ll try that.  and yeah i thought 5 degrees was a lot as well. The gates T291RB timing belt that was recommended for this engine was kinda tight when installing it and with both cams inline with the timing marks, the belt teeth wouldn’t line up with the gear. So I just turned the whole exhaust cam gear like half a tooth so the belt would go on and then adjusted the cam back inline with the timing mark, so some of that 5 degrees is from that. The actual cam has probably only changed about 2-3 degrees if that makes any sense lol also wouldn’t stuff like decking material from the block, head and different thickness of headgasket and the fact that it’s a rb30 bottom end affect the accuracy of the original timing marks?
