Hi guys
Bit of an intro and question all rolled into one..
Just picked up my first Stagea last week - an '02 250t RX.
Last car was a ST246 Caldina which someone decided to get an ultra close look at the back of.....
Very pleased with the Stag - got the leather interior, sunroof (s), reverse cam.
It also came with a very funky 90's style mini mobile remote! It has buttons for start/stop, lock/unlock, trunk & check.
I've popped in some new batteries and the remote powers up - doesn't seem to be paired with the car though... The compliance place said they didn't disconnect anything, so not sure why it wouldn't work.
Has anyone come across one of these and knows how to get it working?
Cheers!
https://www.sau.com.au/forums/topic/416361-remote-start/
Yeah, I got one.
They could have snipped the wires, hopefully not. Get down really low in the drivers footwell. There is a white switch there, flip it.
First up press check. This will flick the car on for half a second and show you the temp inside the car. Make sure all doors and boot are closed. Next, press the start/stop once, it will show the screen, then press it again to start the car. No need to hold down, it will just start. The car will turn off the instant a Door or the boot is opened.
Enjoy.
https://www.sau.com.au/forums/topic/416361-remote-start/#findComment-6683982
^ That's an interesting "feature". Why start your car remotely (sort of cool in a party trick kinda way), & then have it turn off as soon as you open the door to get in? I'm guessing it's a safety feature so little kids don't climb in & drive off (or a thief), but you'd normally be close to the car to use this anyway. Just wondering...
https://www.sau.com.au/forums/topic/416361-remote-start/#findComment-6684003
i think it was mainly for cold area, where before you got in, you could start the car, warm it and the interior up. It defaults to running for 10mins, and then turns off. you can turn it off too with the remote. Also works on hot days :)
dont want Punks stealing your car!
https://www.sau.com.au/forums/topic/416361-remote-start/#findComment-6684028
Thanks PN Mad. Found the switch up under the footwell - mine was black. The lock/unlock function and the check functions work now, but no joy on the start/stop or trunk. When I press the start button it comes up with 00m which is wanting me to input how long to run the car for? Tried mashing a few buttons, but no luck so far. Any ideas?
https://www.sau.com.au/forums/topic/416361-remote-start/#findComment-6684122
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
