just wondering if any of you have swapped out the standard driver's seat in your V35?
if so which seat have you installed/seat rails used, etc.
i am considering doing this as i find the standard seating position quite 'high up', and with helmet on and correct fairly upright driving position the helmet brushes up against the roof - not good! and yes i realize it will involve side-airbag delete.
i am fairly tall (193cm/6ft3) and about 90kgs, and as far as i know there are no shops in Adelaide with Recaros or Brides in stock for me to test sit in. not sure if i would need the XL models?
Are you wanting fixed back or recliner?
Most of the Brides I have seen coming into the country are copies.
Damn good copies too.
I believe the real brides are not ADR, where as the copies are ADR, go figure?
I have Recaro at my work, and have had a bit to do with then in the 3 years I've been there.
The Australian Distributor for Recaro is Ideal Seat Company.
Not all of the seats shown on the RECARO.jp site are ADR compliant.
Go to http://www.idealseat.com.au/ to view the ADR approved range.
We only sell the recliner seats at my work, not the fixed back, so don't know too much about fixed back
If you call Ideal, and ask for Len, he is thier engineer, he can walk you through the mounting and any airbag wiring if needed.
In the listings you will see S, M, L - this refer to the base size, based on your above description, you are wanting the L base.
If you looked at say an Expert L through my work, installed with QLD compliance, you'd pay ~ $2700 for 1 seat installed.
AL
Edited by FUTO_GT
Not with the Recaro's you won't, Len will have a wiring diagram for position sensors and/ or airbags in seat - In the case of air bag in the seat, its usually just a diode installed to the factory airbag wiring to trick it into thinking its still there.
You can get Recaro Ergomed seats with airbags in them, but are exxy as, were talking ~4k just for the seat.
Edited by FUTO_GT
I have a recaro driver side seat that came in my v35 coupe from japan so its got the rails with it, its half leather half suede/cloth style in black. Condition i would say above average no rips or tears, Wont mind selling it if anyone wants just pm me.
located Brisbane
cheers
I have Euro 2 Bride seats with V35 rails in mine. I sit about 2-3 inches lower now than the original seats and they are much more comfortable for every day driving. I sit in the seats, not on top of them.
located Brisbane
cheers
Does it use electric adjust?
Can you post up pics?
Edited by FUTO_GT
I love the Ergomed DS. I was considering installing them in the Maxima whenever the factory seats would wear out but that never happened. If I were to replace the ones in my V36, it would be for the same reason and with this particular model.
If you can, I would suggest you replace the factory seat with a Recaro ASAP. 2 reasons:
1. You get a top seat that will be comfortable, and will hold you in position.
2. If you ever sell the car, remove the Recaro (to fit to the replacement vehicle), and refit a (near) perfect factory seat, which will improve its resale value.
I can but I won't. I don't have any problem with the existing seats. They are comfy and hug nicely so that satisfies your first point. Aside from that, I don't really care about selling the vehicle. I was really attached to my old Maxima and I'm of the view that my decision to go with the V36 was partly subconsciously trying to hang on to that Maxima. There was a lot of sentimentality in it and it's carried across to this guy now.
thanks for the info scotty nm35 and futo gt :)
not sure whether to go fixed or recliner, reclining ones are almost 2x rrp of fixed models. narrowed down to i think:
*bride zeta III typeL
*bride zieg III typeR LowMax
*bride gias II LowMax
*recaro profi spg xl
..i think i'd prefer bride as i love the 80s style gradation pattern :)
oh and no im not interested in anything copy/replica/ripoff.
ok i will put this another way, can you mod plate them?
futo, think i know who and where you work . you do a lot of trucks correct?
As in me, myself mod plate them?
No, we have engineer come onsite, checks install, mounting bracketry and mounting hole positions, and if changing from 3 1/4 bench, and we install seat belt stalk instead of lap sash, checks the threaded point installed, then writes out blue plates.
Done a few trucks and Winnebago's, but mainly 4wd's Chris.
  • 1 month later...
bear in mind if you have airbags in the seats you will have issues with that system when you swap the seat out.
Just as a note, I just installed a Recaro Cross in to my 01 V35 Sedan, the coupe base is the same as sedan, and there is no airbag in the seat, just a position sensor for the driver airbag in steering wheel. For this I just uninstalled the position sensor assembly (4 bolts) from the factory seat and simply placed it under the seat still plugged in. Very Easy to do, no airbag light.
Edited by FUTO_GT
whilst i am not going to get into an argument about this I am going to make a point.
you own the VERY first version of this car and later versions had bags and anti submarine devices in the seat.
so if you wish to still look cool in an accident by all means change the seat and bypass all the safety measures put in place by the factory.
if in doubt drive the vehicle to your local transport compliance and ask in person. in the case of brisbane it in in Zillmere on pineapple st.
m35 s2 axis. look there. also look at m35 s1 and the sedan.
I HAVE changed a few seats out with them and unless you see one set off they are hard to spot.
speak to anyone that has been in a crash hard enough to do the bags in these cars and they will tell you that the seat changes shape in the front .
personally i dont care if you listen or not. your car , your safety and your defect notice if its not legal to change.
Personally I don't care if you help or not... There are many faults that can develop in the airbag circuits on these cars and not every fault can be attributed to the B1161 codes (or anti submarine rams.)
Funny that Nissan have no idea what those codes mean, let alone knowing how to repair them. I have been trying to fix my particular airbag codes for 4 years so far, as have many others, and buying new seats from Nissan obviously isn't an option for most of us. If there was a simple fix to drop a resistor or diode over the faulty unit, at least the other airbags would deploy in an accident... Alas, still no information.
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
