so here is the story ,
I have a gtr32 with hks gtss turbos , power fc full exhaust , tuned on 1 bar.
took it for a spin and gave it max throttle from 2 to 3rd .
drove it for about 2km after that pulled into my street and the idle started hunting. popped the hood and oil had blown out the pod filters and was blowing smoke like crazy .
so I thought I had blown a turbo oil seal, changed the turbo's back to the stock set , cleaned out my induction pipes and intercooler basically degreased every part inside and out.
started the car and the ilde was sort of stable , not hunting but ruff to rev and still blowing heaps of smoke .
iv been told that all the oil that shot to the head came out the crank case vent and into the induction and out the exhaust thus the smoke.
what people havnt told me is why this happened ?
iv also been advised to change my spark plugs and to do a compression test , and to have a better go at getting the excess oil out of the cat and exhaust to stop the smoke.
what are peoples thoughts any input would be great ,
thanks james .
ok so did a compression test and all 5 cylinders are good but i have zero comp in cylinder 1 :( guess the head has to come off to do a visual inspection .
no good.
iv been researching this issue and people say it could also be a broken exhaust valve that is stuck open thus the zero compression. has anyone else had this problem ? as i did hear a slight tick in the weeks leading up to this disaster but thought nothing of it .
thanks james
Start by adding a small amount of oil to cylinder 1 and redo the comp test on cylinder 1.
Did u try retesting cyl 1? Does the engine have a constant missfire? If it doesnt have a constant missfire then its possible the tester wasnt in correctly.
so the results are in and its not good.
i have now done a wet and dry compression test
cyliners 2-6 have normal compression
cylinder 1 has 0 compression .
guess its going to be head off and fix or a new motor. i know rowan nash has like 6 rb26 motors might hit him up :)
yeah i can see a full rebuild coming :(
maybe its time to do it right and big instead of bolt on and hope for the best .
if its a full rebuild might as well use quality forged parts and build the head strong .
might be adding a build thread soon hahah
If you do that, you really have to start deciding if you're building it to a power target or just putting in new "better" stuff to give it the edge. Because of course once you open that can of worms (power targets and all), now you're looking at the oil system, ARP fasteners, etc etc.
I would buy someone's wrecker spec engine to start with, and drive that around while rebuilding/building the broken one (or a replacement if you've stuffed the block!) otherwise it will be off the road forever.
