For every ones info. I replaced the V Spec II sticker on my car, with a genuine Nissan sticker. It was super expensive, but aside from that, the sticker is shaped to match the corner of the back boot like a template. This means that you can use the corners and edges of the boots to get the sticker in the exact factory position. Pretty sweet. I was surprised.
Just checked my spare sticker (my original is just showing a tiny amount of peel on one corner....) - you are right - how clever of them......
Cheers
The Baron
PS That Edward Lee Video should be pinned somewhere as a "must see" for anyone who ever considers buying a car from that guy, with annotations about all the misleading statements.......
Good luck this weekend Bob! :D At the very least I'm sure you will have fun!
Yep had fun but my times were ..........OK????????
My best 1/4 mile was 13.399 (slip attached) but my best terminal speed was 178.94 kph a couple of runs later (111mph).
With that speed I should have been well into the 12's but my 0-30' times are horrible.
I just can get it off the line. I tried it in 2WD mode by pulling the fuse but that was worse!!!!!!
I just sat there and smoked the tyres. :closedeyes::closedeyes::closedeyes::closedeyes::closedeyes:
Anyway, I flogged a few of my mates in stock HSV's and GT Falcons (mid to low 14"s)!
Cheers,
Bob.
Its all in tyre pressure Bob. Need to be 15psi from memory, can't remember exactly but it's a super low pressure.
Once that is set, 2nd gear burn out in rwd mode then flick to awd, on the limiter and release the clutch...when it hooks up you will be shocked what g's these cars can pull on take off.
Mine did a flat 13 when it was stock as a rock...won't get much better than that although I've heard they run a PB 12.8
Thanks Marko,
Modern Motor (April 1990 issue) ran a 13.1 stock........ That's the best I've seen in any publication. Most run around 13.7.
My tyres were set at 27psi for the fronts and 22 psi for the rears...... Guess I stuffed up on that one.
I normally run them at 34 and 30 on the road.
Was pleased with the terminal speed though.
Bob.
At 111mph it's not stock and probably making closer to 270kw at the wheels and should be doing flat 12s or even into the 11s
100% correct........ Unigroup dyno'd it at 271.6 rwkw.
Bob.
what is not stock on the car Bob?
Bar the exhaust, (3.5" front Pipe, 3" Hi Flow Cat, 3.25 Rear pipe, 3 and Hiflow rear muffler) everything you CAN'T see.......
  • Nistune
  • Sard 720cc injectors
  • Lager Walbro fuel pump
  • HKS Boost Controller
  • Splitfire coils
  • Excedy HD Clutch
Bob.
  • Nistune
  • Splitfire coils
  • Excedy HD Clutch
Bob.
nice. The Walbro pump is not to noisy?
No....... The exhaust must drone it out!
A mate of mine had a Brock Commodore VK Group A that was tricked up with a Walbro pump and that was horrendously noisy so I know what you mean.
Bob.
Cheers,
Bob.
That's still very respectable, and at least you had fun... that's the main part!
How were you launching the car Bob? These things need a little tough love from the start line, you might feel bad in doing it but it's what she's made for :) There's absolutely more to be had from your car, your 60 foot time of 2.1s could come down to 1.6 to 1.8 seconds with a bit of practice - I'm not a drag racing expert by any stretch of the imagination but that little bit shaved off the front end often seems to translate to a larger amount shaved off at the other end.
Well done in any event, at least you came out the winner against the HSVs and FPVs! :)
  • 1 month later...
So just an update on my gtr,
Installed new timing belt, HKS cam gears, water pump etc,
Bought a power fc and some hks 550cc injectors.
I had a second hand apexi avcr so I just used the boost solenoid and wiring and converted it to my power fc.
Got the car back from the tuner today and made 265kw's on 1.1bar boost!
Pretty happy and the car feels a hell of alot more alive than before!
  • 3 weeks later...
Hey guys,
I've been off sau for a year or two. Sure we used to have another rare register with a good record of vpsecs and n1s? I'm probably just lost tho, lol.
Anyway adding for the community, in Brisbane with a 1994 Vspec II N1. Unfortunately not very standard! :-)
Cheers
Michael
Fortunately, Australia has acquired 2x BNR32 V-Spec II N1 in recent times.
Congratulations to you Michael as well.
We'd like to grab them before Canada's timeline permits...
Last six digits on mine are -311603
It's still awaiting compliance.
  • Like 2
is that a genuine N1 Terry?
Car looks very nice.
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
