I had a Japanese guy (Indy from IS Motorsports) look at my car about 10yrs ago and he never seen or heard of an ADM, I explained it to him and he found it interesting but I think he still preferred his bayside blue r34
Re-Auction result on the N1 Vspec II, 50,000km, grade 4 B yesterday, Sold around 3,100,000 yen, around $44,000 landed and complied + on roads. That's seems to me a bit of a bargain, however condition in person was probably not as good as the auction report suggested.
Thoughts?
Thoughts?
sell, wife, kids, pets, borrow from mob - acquire car and restore it to prestine condition and profit?
Thoughts?
You saying that only cause, due to the bargain price it sold for?
O'seas buyers as well as Aussie buyers bid for that VS2 N1.
The seller had second thoughts about his reserve this wk > more realistic.
No bubbling paintwork but surface rust underneath abounds.
It might have thrown some bidders off, but it shouldn't have.
Wishing the Aussie successful bidder all the best...
particularly whilst a UK seller is asking for over 90,000 pounds (i understand)
  • Like 1
Just wanted to reiterate what Bob said a few pages back, buy the best car you can, within a reasonable budget.
Generally speaking you will end up with a nicer/more original car AND save money.
Bargain at the start very rarely is in the long run.
Absolutely
And looking at all of the detailed pictures of the VS II N1, it was not in very good condition. 4B was a huge exaggeration in the actual quality of the car.
It's interesting that it has climate control and a radio
a lot of the N1's appear to have been factory optioned that way
I've yet to see an N1that has one :wacko:
I've yet to see an N1 ithat has one :wacko:
Agree.
I keep in touch with a few owners and only know of 1 in Canada that is without both.
Some nice cars in here, can anyone help me out with the part numbers for the front section of the nismo 3 piece side skirts? The part that attaches to the front guard?
I used someone's chassis number to order the correct bolts to put r33 brembos on the front of my r32 since the r33 bolts are too long. I'm hoping the bolts for the r32 brembo equipped cars will be the right length.
Thanks guys
Talking to jesse streeter, I need a chassis number to go with the numbers above in the above pic. Does anyone know for sure there gtr had these nismo 3 piece skirts from the factory. Maybe I need a chassis number from one of this nismo r32's
You should just be able to buy the Nismo 3 piece side skirt on its own...
Try Import Monster / Just Jap / RHD Japan.
interesting. That drivers seat is pretty worn for such a tiny amount of k's! 6.5 Mill yen is not completely outrageous, but probably a little steep. However i suspect that it is worth all of a 5 mill yen price tag. That front lip needs to be painted 326 crystal white! Remove those stupid V Spec II N1 badges (particularly since it is not a V Spec II) from the back boot, take out that stereo and replace those rubbish tyres. Aside from that, over all it looks like a clean original V Spec N1.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
