I'll see if I can find any links but for some reason I've always thought there were 2 codes for the N1. If yours is a fake then someone had spent more making it look like one than what an original would be worth so doubt it :)
Yep, it seems you guys are right. I must have been on crack or something at the time, because I've had it in my head all along that there was a ZY n1 which referred to the V-spec I/II based models.
Ok - took delivery of my car last Friday and its now fully registered.
'Racepace' here in Melbourne put it through its paces and it got excellent compression of 175-180 all the way through. We removed the boost restrictor and I get 196 rwkW nothing more planned at the moment.
Some of the vinyl needed some loving and there is a small corrosion hole in the exhaust - nothing serious.....
We mounted a Rapfix quick release and Momo as well - only thing required now is the Blaupunkt stereo.
Also received the full service history in the mail today. The car did 800kms in the last 11 years, which seemed to mainly consist of the 25 kms round trip to the Dealer twice a year. I wonder what the story behind that is......
Needless to say I've put about 6 years worth on it in 1 week (is that bad ;-)
I'll take some nice pictures when the Melbourne weather is better
Cheers
The Baron
Sick. That's awesome Baron.
Drive her and enjoy her. Mine gets used daily by me or the wife. It's regularly doing the school run. My boy is the only kid at his school that gets in and out of the back of an R32 V-Spec. He loves it.
One of the motivations was definitely to be the coolest dad dropping off the kids. The child seat for my daughter sits remarkably well in it ;-)
Cheers
The use it or lose it Baron
Finally found the dyno chart from when i had mine tuned.
The bottom line is stock, and the top is 16psi. Both are with everything stock except Nistune ECU, exhaust and pod filters. Started maxing out the AFM's so we stopped, but has had that tune since 09 and for me its perfect. That curve is why i love the N1's. Very drivable.
Not bad for a stockish 20yr old car :)
Thats interesting NISMO. I dyno'd my R32 N1, completely stock in everyway, including exhaust, airbox, ECU and boost. On the 4 wheel hub dyno it ran 180kw at all 4 wheels @ 0.8 bar boost. Which is pretty much exactly what it is supposed to be as per the factory spec. The most interesting thing is that the car didnt make full boost until about 5,200rpm. Which makes sense as they are N1 a/r 0.64 turbos. My assumption is that they are designed to be running much higher than the stock 0.8 bar, but restricted them to that to meet the 206kw gentlemans agreed power limit.
Even though it is not running huge dyno numbers, and it doesnt make max boost until 5,200 rpm, it is still quite a bit quicker around my local track than my previous stock R32 GTR. So that is sweet.
  • 3 months later...
Sorry for the thread dig, I got all excited when I found this
Here is my car:
V-Spec - build date 11/93
'Chassis No' : BNR32-305724
'Model': KBNR32RBFSN NA - not sure what the deal is here?
I picked the car up originally from Fuji Motorsports in sydney early 07. Long story short, I sold it October 07.
I was browsing car sales in October 13 and BAM there it was, some phone calls were made and my fiance gave me the nod, picked it up a few days later.
Mods include,
Apexi coilovers, hks super dragger cat back exhaust, trust body kit, nismo bonnet and boot lips, no BBS rims. all imported with the car
Since I bought it back I have been tidying it but and fixing a few things for rego.
I'll try get some pics uploaded asap
Here is my car:
Mods include,
Hmmm....... Does it have an driver's side airbag and is it missing the rear wing?
Yup has a drivers airbag and has both standard gtr spoiler on and nismo lip.
According to the VIN decoder that I use it should have the air bag but NOT the rear wing.
It may have been added later on.
    • Have you not seen geospy.ai? It can now give GPS co ords to within a metre from a photo, even if it's a random photo you take inside. Supposedly at the moment only the government/law enforcement has access to that... Supposedly...
    • I've got the rear ones, they're certainly beefy. I need to take them to my driveshaft guru to check over, he's very fussy about the quality of components so I'll let you know if they are made of cheese by a blind man.   Are you in Australia? A mate just had a set of EN26 shafts made for his K20 Lotus by our fabricator which were quite cheap (compared to Driveshaft Shop) so if you can procure the CV's and draw what you need he'd make them for ~$800 for the pair.
    • Had I known the diff between R32 and R33 suspension I would have R33 suspension. That ship has sailed so I'm doing my best to replicate a drop spindle without spending $4k on a Billet one.
    • OEM suspension starts to bind as soon as the car gets away from stock height. I locked in the caster and camber before cutting off the kingpin. I then let the upright down in a natural (unbound) state before re-attaching it. Now it moves freely in bump and droop relative to the new ride height. My plan is to add GKTech arms before the car is finished so I can dial camber and caster further. It will be fine. This isn't rocket science. Caster looks good, camber is good, upper arm doesn't cause crazy gain and it is now closer to the stock angle and bump steer checks out. Send it.
    • Pay careful attention to the kinematics of that upper arm. The bloody things don't work properly even on a normal stock height R32. Nissan really screwed the pooch on that one. The fixes have included changing the hole locations on the bracket to change the angle of the inner pivot (which was fairly successful but usually makes it impossible to install or remove the arm without unbolting the bracket from the tower, which sucks) and various swivelling upper arm designs. ALL the swivelling upper arm designs that look like a capital I (with serifs) suck. All of them. Some of them are in fact terribly unsafe. Even the best one of them (the old UAS design) shat itself in short order on my car. The only upper arm that works as advertised and is pretty safe is the GKTech one. But it is high maintenance on a street car. I'm guessing that a 600HP car as (stupidly, IMO) low as you are going is not going to be a regular driver. So the maintenance issues on suspension parts are probably not going to be a problem. But you really must make sure that however your fairly drastically modded suspension ends up, that the upper arms swing through an arc that wants to keep the inner and outer bolts parallel. If the outer end travels through an arc that makes that end's bolt want to skew away from parallel with the inner bolt, you will build up enormous binding and compressing forces in the bushes, chew them out and hate life. The suspension compliance can actually be dominated by the bush binding, not the spring rate! It may be the case that even something like the GKTech arm won't work if your suspension kinematics become too weird, courtesy of all the cut and shut going on. Although you at least say there's no binding now, so maybe you're OK. Seeing as you're in the build phase, you could consider using R33/4 type upper arms (either that actual arm, OEM or aftermarket) or any similar wishbone designed to suit your available space, so alleviate the silliness of the R32 design. Then you can locate your inner pivots to provide the correct kinematics (camber gain on compression, etc).
