That's right, that's happening!
I'm doing a much of the work as I can too.
I got the RB30 block from my old VL commodore after I cooked the head in good old VL commodore fashion. :)
I've just finished tearing down the short motor and everything is pretty much bang on with factory tolerances which is awesome.
The deck needs a machine as it's slightly high in between two of the cylinders.
The head I've got is coming off my the RB25 that was in my 33 until I cooked it. it's a little melted in cylinder #1 as you might have seen in my other thread, it's also not perfectly straight, but I was thinking if I take about 0.8mm off the head it'll remove all the melted crusty shit and increase my compression ratio too. As 25\30 combinations with stock RB30 short motor and stock R33 25 VCT head will yeild about 8.2:1 Compression Ratio, saving the head that much will reduce the Combustion chamber volume by about 7cc which will increase the compression ratio up to around 9:1.
I'm not sure if I want to do that yet though, with the doughy compression ratio and a safe tune I'll be able to use the shitty fuel, down on the peninsula and other Rural areas that I frequent, safely.
I just measured my head and it was 61cc. While I was measuring it I left the water in there for an hour and found all the valves leak a little, some more than others, but they'll all need some love.
I plan to do the internal VCT mod as outlined in this thread. http://www.skylinesaustralia.com/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/ Page 5 'The mafia' comments with some pics that breaks down the process really well. Looks easy enough :)
After reading the 25\30 thread in the forced induction section, it all looks too easy... (famous last words)
The only thing on the shopping list is an oil pump, I'm thinking stock RB25 until should do the job? If anyone has one lying around after an upgrade, let me know!
I think I'm almost at the stage where I can send stuff off to get machined! It's looking good so far :)
https://www.sau.com.au/forums/topic/416493-zoid-builds-a-2530/
Pics
RB30 goodness
:D
Proof of concept
Measuring combustion chamber and valve leak testing.
After about 1 hour this is what they all looked like
This piston is the only one I'm worried about, opinions? Spark plug ceramic trolled it.
Extended shopping list:
Oil pump
Water Pump
Full length crank collar
Oil restrictors
New bearings
New head bolts\studs
New head gaskets.
Bottom timing belt gear.
Harmonic balancer
If anyone has this stuff lying around, let me know!
I'm also after a turbo, not decided on what I want to do yet though :/
Edited by zoidbergmerc
This is for the VL isn't it? Not your 33...
.8mm is chopping a fair bit out of a 25 head... I'll be interested in what Matt/insert chosen machinist has to say about it. You'll have to watch your valve clearance too. That head looked pretty fkn cooked though!
I have some slightly used wiseco rb25/30 pistons/pins/locks without rings going cheap if you wan't some :-)
If it's just a slapper, the sparkplug tip damaged piston will be okish, just smooth the divits out a little, also check the bore very carefully.
I have some 25/30 bits and bobs kicking about. I'll have a look, see what I can find.
The conversion is easy. There are a couple of things that arn't covered in the guide, sing out if you need a hand.
J.
When you measured the head did you put clear platic + grease over the combustion chamber for an accurate measurement? 0.8 will not give you 7cc, 86mm diamiter at 0.8 height gives you 4.6cc, so it will probably be 4cc by the time you equate for the sqish zones.
I asked Rodgers to take 4cc out of Steves RB20 head (stock head is 40cc), and he wouldn't do it. He would only change the deck height on the block. He will be able to sort the piston though.
I can't see valve clearance being an issue with the design of the rb30 piston, what is the volume of the piston dish?
Use brake cleaner to test the valve seal before final reassembly, If you used it now it'd be alike a tsunami coming though.
J.
Yeah this first one will go in the VL, assuming it's a raging success I might build another one for the 33 :)
I might take you up on that offer for extra assistance. Let me know what bits you've got, I might require them.
The bores are pretty healthy, they've got some marks where the pistons were sitting stationary for 5 years though, and that comes out rather that eating in, so I'm assuming that can be honed out, the marks came off the piston skirts with a good rub.
I've got to drop some stuff off to Rogers on Wednesday so I'll spin a yarn and see what he reckons.
You're right about the cc part too, f**k knows what was wrong with my maths :P
When I did the head CCs I didn't have any grease or plastic so I just made sure it was perfectly flat and ran a ring of detergent around the lip of the combustion chamber to eliminate the meniscus.
Measuring the Piston dome trolled me a little, it took a while to figure it out, it's got a little dome and a little valve relief. I could measure the relief quite easily but to measure the dish; I made some play dough and pressed the piston into it and measured the dome like it, it wasn't the most accurate way to do it but it's all I could think of :/ By my awesome calculations, the valve relief pretty much cancels out the dome. Both 3.9cc
I'll be sure to clean up the valve seats and try it again later :) It wasn't quite a tsunami, but it wasn't pretty...
are the pistons domed or dished in the middle? it's hard to tell from the photo.
You'd be best just to get Rodgers to reseat the valves, it's not that expensive, and it'll save you 11ty hundred hours
They're domed in the middle, and dished with the valve relief is.
I'm trying to do as much as I can in this engine build, so next time when I hand over my hard earned cash I can fully appreciate the value of the work being done.
Hey Nowley,
Do you have turbo/hot side allready? Do you have a loom ecu yet?
If not, why not put a single cam head back on?
With all the money/time you save, you can put a nice big cam and rocker gear in.... and be able to use the stock loom with a nistune in the VL ecu.
... just a thought
Justin.
There is actually a high flowed 34 turbo here....
Hmmmm.
I don't rate hifliws buy on a 3l it wouldn't be to bad. Depends what you are after. I've got exhaust manifold and turbo lines if you think you mite go that way.
yeah I've still got my stock exhaust manifold and a small collection of turbo lines. So I should be right. I'll keep it in mind though :)
I was also eyeing off that GT3540 for sale in the other thread, will that fit in stock low mount position?
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
