That's right, that's happening!
I'm doing a much of the work as I can too.
I got the RB30 block from my old VL commodore after I cooked the head in good old VL commodore fashion. :)
I've just finished tearing down the short motor and everything is pretty much bang on with factory tolerances which is awesome.
The deck needs a machine as it's slightly high in between two of the cylinders.
The head I've got is coming off my the RB25 that was in my 33 until I cooked it. it's a little melted in cylinder #1 as you might have seen in my other thread, it's also not perfectly straight, but I was thinking if I take about 0.8mm off the head it'll remove all the melted crusty shit and increase my compression ratio too. As 25\30 combinations with stock RB30 short motor and stock R33 25 VCT head will yeild about 8.2:1 Compression Ratio, saving the head that much will reduce the Combustion chamber volume by about 7cc which will increase the compression ratio up to around 9:1.
I'm not sure if I want to do that yet though, with the doughy compression ratio and a safe tune I'll be able to use the shitty fuel, down on the peninsula and other Rural areas that I frequent, safely.
I just measured my head and it was 61cc. While I was measuring it I left the water in there for an hour and found all the valves leak a little, some more than others, but they'll all need some love.
I plan to do the internal VCT mod as outlined in this thread. http://www.skylinesaustralia.com/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/ Page 5 'The mafia' comments with some pics that breaks down the process really well. Looks easy enough :)
After reading the 25\30 thread in the forced induction section, it all looks too easy... (famous last words)
The only thing on the shopping list is an oil pump, I'm thinking stock RB25 until should do the job? If anyone has one lying around after an upgrade, let me know!
I think I'm almost at the stage where I can send stuff off to get machined! It's looking good so far :)
https://www.sau.com.au/forums/topic/416493-zoid-builds-a-2530/
Pics
RB30 goodness
:D
Proof of concept
Measuring combustion chamber and valve leak testing.
After about 1 hour this is what they all looked like
This piston is the only one I'm worried about, opinions? Spark plug ceramic trolled it.
Extended shopping list:
Oil pump
Water Pump
Full length crank collar
Oil restrictors
New bearings
New head bolts\studs
New head gaskets.
Bottom timing belt gear.
Harmonic balancer
If anyone has this stuff lying around, let me know!
I'm also after a turbo, not decided on what I want to do yet though :/
Edited by zoidbergmerc
This is for the VL isn't it? Not your 33...
.8mm is chopping a fair bit out of a 25 head... I'll be interested in what Matt/insert chosen machinist has to say about it. You'll have to watch your valve clearance too. That head looked pretty fkn cooked though!
I have some slightly used wiseco rb25/30 pistons/pins/locks without rings going cheap if you wan't some :-)
If it's just a slapper, the sparkplug tip damaged piston will be okish, just smooth the divits out a little, also check the bore very carefully.
I have some 25/30 bits and bobs kicking about. I'll have a look, see what I can find.
The conversion is easy. There are a couple of things that arn't covered in the guide, sing out if you need a hand.
J.
When you measured the head did you put clear platic + grease over the combustion chamber for an accurate measurement? 0.8 will not give you 7cc, 86mm diamiter at 0.8 height gives you 4.6cc, so it will probably be 4cc by the time you equate for the sqish zones.
I asked Rodgers to take 4cc out of Steves RB20 head (stock head is 40cc), and he wouldn't do it. He would only change the deck height on the block. He will be able to sort the piston though.
I can't see valve clearance being an issue with the design of the rb30 piston, what is the volume of the piston dish?
Use brake cleaner to test the valve seal before final reassembly, If you used it now it'd be alike a tsunami coming though.
J.
Yeah this first one will go in the VL, assuming it's a raging success I might build another one for the 33 :)
I might take you up on that offer for extra assistance. Let me know what bits you've got, I might require them.
The bores are pretty healthy, they've got some marks where the pistons were sitting stationary for 5 years though, and that comes out rather that eating in, so I'm assuming that can be honed out, the marks came off the piston skirts with a good rub.
I've got to drop some stuff off to Rogers on Wednesday so I'll spin a yarn and see what he reckons.
You're right about the cc part too, f**k knows what was wrong with my maths :P
When I did the head CCs I didn't have any grease or plastic so I just made sure it was perfectly flat and ran a ring of detergent around the lip of the combustion chamber to eliminate the meniscus.
Measuring the Piston dome trolled me a little, it took a while to figure it out, it's got a little dome and a little valve relief. I could measure the relief quite easily but to measure the dish; I made some play dough and pressed the piston into it and measured the dome like it, it wasn't the most accurate way to do it but it's all I could think of :/ By my awesome calculations, the valve relief pretty much cancels out the dome. Both 3.9cc
I'll be sure to clean up the valve seats and try it again later :) It wasn't quite a tsunami, but it wasn't pretty...
are the pistons domed or dished in the middle? it's hard to tell from the photo.
You'd be best just to get Rodgers to reseat the valves, it's not that expensive, and it'll save you 11ty hundred hours
They're domed in the middle, and dished with the valve relief is.
I'm trying to do as much as I can in this engine build, so next time when I hand over my hard earned cash I can fully appreciate the value of the work being done.
Hey Nowley,
Do you have turbo/hot side allready? Do you have a loom ecu yet?
If not, why not put a single cam head back on?
With all the money/time you save, you can put a nice big cam and rocker gear in.... and be able to use the stock loom with a nistune in the VL ecu.
... just a thought
Justin.
There is actually a high flowed 34 turbo here....
Hmmmm.
I don't rate hifliws buy on a 3l it wouldn't be to bad. Depends what you are after. I've got exhaust manifold and turbo lines if you think you mite go that way.
yeah I've still got my stock exhaust manifold and a small collection of turbo lines. So I should be right. I'll keep it in mind though :)
I was also eyeing off that GT3540 for sale in the other thread, will that fit in stock low mount position?
    • PRICE  : $1400 LOCATION   : NSW Central Coast FIT  :  All Nissan 350Z type Z33 and Infinity G35 Coupe. See delivery note. Hi, brand new, unused, still in the box.  ($1850.00 is what i paid ) My bad luck !!! I thought my right front  Bilstein was cactus so i bought the ST 's to replace all.  Turns out the right front is fine ( loose mounting after service  by a well known importer of Bilsteins ) So im selling the ST's. They are made by KW ( no intro needed ) . Iam on the Central Coast and im willing to meet up in Sydney metro, within reason and Newcastle.
    • Yep, yeah would need to do the flywheel although the 6 bolt NA clutch can handle a 20de if just wants to replace the stocker.
    • No it's fine. Heat sleeve is a thing. With oil running through it it is unlikely. Engine off heat soak can be a thing though. There is no way that you have a leak through the hose. That has pressure behind it and any small hole will turn into a large one in very short order. It is so much more likely to be leaking from the connection.
    • Really? That's piss weak. I didn't know they hobbled the shitboxen that badly. OK. So probs need to buy a flywheel too. But that's not too bad.
    • Hi all. I already posted some newbie-ish questions here and there but this will be my first "big" post. Last summer I went and fulfilled a kind of childhood wish, because I just thought I needed this experience in my life no matter what. The car I bought is a mildly modded 1995 BCNR33 Vspec. It was repainted to a metallic orange color all around and it had all windows reseated. Not so well done black respray in the trunk and a metallic black in the engine bay. From outside it looks very nice except for a minor paint error on the roof and the rear spats needing new adhesive tape. The inside is pretty clean and no broken plastics, missing or faded buttons. Even the adjustable mirrors and trunk antenna work like a charm. Despite a moderately long list of issues I don't (yet) regret buying this car. Most mechanical problems are just due to age, like worn rubbers here and there. The underside sadly has lots of corrosion, especially to the back. It looks like it either has been driven in the winter for a while or it lived near the saltwater in Japan, the rust is nothing terrible but it'll require to be looked after. Mostly panel gaps and all the mounted components underneath are a bit crusty, but I don't think anywhere has progressed so badly that there's going to be holes. Front right jacking rail is crushed and needs some care so it doesn't develop into a rust crater at some point. Worst part is definitely the strut towers. I thought they looked fine but after taking off the strut bar I noticed that it actually started bulging up on the passenger side. Probably would have passed on the car or negotiated down by some thousand Euros more if I had noticed this before buying, but here we are. Trunk area also has signs that there was a water leak to the interior once but nothing too crazy, I guess lots of Skylines had this at some point. As for the list of (known) issues, I'll try to make this compact. I hope the coloring is self explanatory. Mechanical: -Various busted or soon-to-be busted rubber bushings and ball joints. Will replace ball joints with OEM or better and bushings with polyurethane where possible. -Shaking steering wheel at above 80kph -downshift from 5th to 4th is a bit crunchy unless I rev-match, might just try to renew the shifter assembly, but it's not a priority issue -tailshaft centre bearing could use a replacement, is it worth going 1-piece tailshaft as it doesn't look too fresh all around? Chassis: -underbody corrosion on many spots and in hollow spaces, needs to be treated -corrosion on many bolts, hoses, lines, suspension components, subframes, will be treated when replacing of the bushings is needed as time goes on -strut tower top panels and some of the surrounding panels are rusty, so needs fixing. Will look into doing this with a buddy in the winter, otherwise bite the bullet and pay a professional -driver side door is misaligned to the body and needs to go a slight bit more inwards -both door windows are misaligned and have an airgap where the window meets the door at the B pillar -The Aerocatch latches for the bonnet have locks but no keys, need new keys. -driver side door window is kind of gritty and could use a polish -damaged jacking rails and front frame rails, from people lifting the car the wrong way, might have this fixed by a bodyshop Electrical: -Nismo tachometer is just bouncing and displaying nonsense, supposedly worked fine when the stock ECU was still in the car -An old Greddy boost controller sits on the dash which will be removed as it servers no purpose anymore. -a led segment rpm gauge is on the steering column, will probably also be (re-)moved once the Nismo tacho is working correctly -there was an attempt to make the sound system better by the previous owner but it was just inducing noise all the time, ripped out the amp and filters in the back, no music for now -trunk antenna goes up as long as the radio is on regardless of the mode, I want it to only rise if I choose Radio specifically or per switch -3rd brake light is a bit dimmer than the taillights but everything was converted to LEDs so mabye now it just seems dimmer? -reverse light flickers, have to test if that behavior changes when I fiddle with the gear stick. Hope I can get around changing the switch. -Left side taillight, blinker section has minor water intake and is humid after washing. Other side has a hole in it, probably for that exact reason. I'll probably reseal them entirely and plug the holes. Engine: -minor coolant drips on one or the other hose -rear turbo leaks oil onto the exhaust making the car essentially undriveable due to fire hazard -Oil filter relocation kit has an oil drip at the Dash lines, will probably make a new connection there and tighten real good and pray -throttle body assembly is slightly stuck for the first throttle pedal input after sitting for a while I'm always open to suggestions and advice from more experienced people, I'm sure half of this list is easily dealt with and just requires some time and effort to sort out properly. Once I have some proper pictures of the car I will post some in this thread, I just have to remember to take some more once I get the chance to. Will post updates when I have news on anything, I want to try to keep this thread as kind of a logbook as well. Ultimately my goal for this car is to just enjoy it. An engine rebuild is probably going to happen sometime as well, because it is old after all. It will never be fully new again, I am just not that rich. But I want it to look good, work well and not rot away while I drive it. I'm probably gonna spend a lot of money on this journey, hopefully not an unreasonable amount.
