I've taken .120 plus " off these heads and just remilled the oil feed relief, piston to valve like Ben suggested can be an issue as the VCt in the 20 deg advanced position will net you up to .180" lift at dtc on the inlet and by reducing the deck face the valve drop to head face will be reduced by close to same amount, this will vary on where the cams are dialled in. You will need to get Hollywood to straighten it first before you surface it unless you have a special set of cams with a bend in them to suit your as stated not perfectly straight cam tunnels and then just never rotate them!
What ever you need as listed above I have and no longer will be using off my shit box Datsun as heading down another path on the new engines let me know if I can help.
I was also eyeing off that GT3540 for sale in the other thread, will that fit in stock low mount position?
Why dont you see if you can borrow jacks for a test fit........... he's not using it lol
I doubt it mainly for the compressor housing.
Yeah, you'd have to space it out a fair bit.
I don't rate hifliws buy on a 3l it wouldn't be to bad. Depends what you are after. I've got exhaust manifold and turbo lines if you think you mite go that way.
Exh housing is too small for the 3lt, even the OP6 r34 housing... too much back pressure... ping ping ping
One of the best rb set ups I ever had together was the 25/30 in my old r32 gts-t.... 25/30, T6725g and 4.3 gears :-) so much torque! pretty much stand on it anywhere over 2k and it was wheel spin city!!
Maybe a td06 20g and get a t3 rear housing with v band dump to suit and whack an external gate on your std mani.
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
