guys I'm wrecking a r33 series 2 gtst auto
Rb25det series 2 motor from 97 model
Blue painted covers
Complete with Loom and ecu
115000kms
$1250
R33 series 2 auto gearbox has been modified and tricked up not sure exactly but also comes with a trans cooler
$150
Bare series 2 rear subframe
$25
rb25det series 2 afm pink label great upgrade for rb26 just need 1 more
$75
r33 gtst rear 5 stud conversion
hubs
rotors
calipers etc
$250
r33 gtst front hubs, rotors and brakes good for 5 stud
$250
r33 series 2 gtst drive shafts
great condition
$40ea
r33 rear king springs and shocks sit perfect shocks have seen better days
just swap the springs into your shocks
$30
R33 impul shocks and springs
$40
r33 gtst series 2 brake master complete abs
great condition
$50
r33 engine crossmember perfect for rb conversions
$70
R33 series 2 power steer rack
Great condition
$40
R33 front strut brace
$40
r33 front sway bar
$20
r33 series 2 behind the dash aircon stuff
make a offer
r33 series 2 window trims from door and car the one that always fade
make a offer
r33 gtst series 2 ecu
$60
r33 series 2 gtst engine loom perfect condition
$150
r33 overflow bottle
$15
r33 gtst series 2 front seats
Great condition
$50
r33 gtst series 2 door cards front and rear
good condition
$100
r33 gtst xforce catback exhaust with high flow cat $140
R33 gtst split dump and front pipe stainless very well made $80
r33 fibreglass rear bar looks awesome
prefitted just needs to be painted
$30
R33 gtst series 2 ignition barrel and locks with key
Good condition
$130
R33 gtst series 2 side mirror passenger silver
$30
r33 passenger side gaurd with blinker
Silver
$30
R33 gtst series 2 centre console
Good condition
$20
R33 series 2 door passenger
good condition
$30
R33 gtst tail lights
Great condition
$30 each
R33 glovebox
$20
R33 handbrake with full handbrake cable to hubs
$50
R33 pasenger window reg motor
$35
R33 passenger window switch
$20
R33 bonnet latch and cable
$50
R33 bonnet latch bracket
$40
r33 boot and fuel flap latch assembly
$30
r33 series 2 air con unit/display
$30
R33 series 2 complete air con set up with everything!
$150
i have all the interior plastics etc
So much more just can't think text me or pm me if you need anything
Gold Coast can post
0487924497
https://www.sau.com.au/forums/topic/416524-r33-s2-parts-galore-wrecking/
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
