Hi Guys,
The time has come to move on from this project and onto the next one. This is a heavily modified example of a 1993 Nissan 180SX with over 100k spent on the build. Detailed mods list is below as are photo's of how it currently sits. Car was featured in Fast Fours when it had the previous motor setup in it.
BODY (over 30k spent on fab work alone which was all carried out by Roadrunner fabrications)
1993 Nissan 180SX
Custom wheel tubs (suit the lines of the bay alot better then trailer guards)
Rear guards cut higher to fit bigger wheels and metal flare to protect wide body
Custom gearbox tunnel to give plenty of clearance to the RB25 gearbox allowing for easy removal of box
Custom raised floor section for exhaust from firewall back allowing the dump pipe to tuck up above the chassis rail
Custom removable front end rad support
Completely seam welded front to rear
CAMS spec weld in full cage cage goes through fire wall to strut towers aswell
All holes in firewall welded up and smoothed over
Genuine BN Blister full kit including front and rear guards (over 3.5k for the kit alone)
Fiberglass vented bonnet
Type x tail lights and cente panel
Custom fixed headlight setup
Custom cover over spare tyre well sealing fuel system off from the cabin
Custom bash bar in place of front reo
All sound deadening removed front to rear
New windscreen (replaced after cage was done)
Tinted windows
Freshly resprayed gloss black outside and green inside
ENGINE
S15 SR20DET
Tomei Easycams 256/264 10.5mm
Tomei Rocker Arm Stoppers
Custom rocker cover with twin -10 breathers
Engine tested with even 160psi comp accross all 4 cylinders and 2% or less leakage per cylinder before going in
TD06-20g 8cm rear with allow elbow welded on
BRAE Steam pipe manifold
Precision 46mm wastegate with screamer pipe
Custom 3.5" exhaust tucked up as high as possible into twin 3.5" stainless tips. Has a removable muffler at the rear and is currently running as a straight through exhaust.
Speedflow fittings and teflon lines used throughout
DRIVETRAIN
RB25DET box with New PAR 1-3 straight cut gears, billet input and output shaft, new genuine Nissan syncros, bearings, forks (rebuilt less then 100km ago)
Custom bell housing to bolt the rb25 gearbox to the motor
Exedy single plate clutch (less then 100km on it)
Custom 2 piece tail shaft to suit RB25 box
Custom shifter to suit gearbox position
Custom gearbox mount
R32 gtr rear end including diff, driveshafts and hubs
R32 gtr diff rebuilt less then 100km ago with additional nismo clutch plates making it a full 2 way mechanical diff
R32 gtr driveshafts rebuilt less than 100km ago
FUEL SYSTEM
Bosch ID1000 1000cc injectors (less than 100km old)
2x Bosch 044 pumps
600hp Denso feed pump
Custom 4L surge tank
Pumps and surge tank custom built into spare tyre well and custom cover completely seals them off from the cabin
BPP Billet fuel rail kit which allows you to swap to top feed injectors whilst retaining factory plenum (to keep mid range torque)
Turbosmart FPR-2000 Fuel pressure regulator
Twin -6 alloy feed lines with a -8 return (no factory lines used and have been removed)
ENGINE MANAGMENT/IGNITION
Vipec V44 ECU
M&W Pro 16 CDI
6x Bosch coils (only 4 are used 2 are spares)
Custom top gun leads
SUSPENSION/BRAKES
Driftworks CS2 coil overs
Driftworks adjustable traction, camber and toe arms in the rear
Driftworks adjustable castor rods in the front
Driftworks adjustable lower control arms front and rear
Driftworks front and rear knuckles (50mm roll centre correction, improved geometry and more lock)
Driftworks solid cradle bushes and diff bushes
Cusco adjustable tension rod brace
Modified s15 rear cradle (30mm increased track over s13 cradle and improved rear gemometry)
Tien tie rods and tie rod ends
Driftworks offset steering rack spacers
Reconditioned S14 steering rack
New rack bushes
R32 GTR front calipers with Ferodo ds2500 pads and slotted rotors
Freshly rebuilt S15 rear calipers with Ferodo ds2500 pads and new rotors
Custom Hydraulic hand brake
Custom modified pedal box with adjustable front & rear bias (no booster)
WHEELS/TYRES
Weds Kranze LXZ 18x9.5 -16 Mid disk front, 18x11 -15 Lo disk rear
Have 8 of these in total, 6 rears (all 18x11 -15 Lo disk) and 2 fronts. 2 of the rears are brand new, 2 have been used for 1 track day and the other 2 are as old as the fronts.
Brand new Achilles ATR 265/35/18 rear
Falken FK452 225/35/18 front (less than 50km old)
INTERIOR/ELECTRONICS
S15 dash
S15 cluster
Custom carbon fibre switch panel which contains all switches for the car including lights, indicators, window switches etc
Carbon fibre door seals
Saber 60mm water temp, oil temp, fuel pressure and oil pressure gauges with warnings and recall
Turbosmart eBoost 2
AEM Wideband o2 gauge with sensor mounted in dump pipe
Sparco Evo 2 fixed back drivers seat solid mounted to the floor
Takata 4 point harness
Vertex 330mm steering wheel (would like to keep this) with quick release boss kit
Car has been completely rewired front to rear with no factory wiring reused. All wiring has been tucked and very little of it is visible.
Battery mounted in battery box behind where passenger seat would be
ENGINE ACCESSORIES/COOLING
Custom 5L oil catch can with external drain
Custom coolant overflow
Custom power steering reservoir
Saber 42mm radiator modified to allow 2 16" thermos to mount to the front of it
Saber intercooler with modified end tanks flipped upside down and custom mounted just in front of radiator allowing for short intercooler piping
Custom intercooler piping designed to be as short as possible
Saber 17 row cooler
PWR 12 row power steer cooler
All the lines throughout the car are braided teflon and silicon vacum lines with speedflow fittings (over 5.5k spent on fittings and lines alone)
PHOTOS
And an old one with the previous seats in it to show the cage better
Car is currently tuned for reliability making 270rwkw on 20 psi and is tuned on E85. The car is complied with no accident history and was registered until rego ran out. It can be registered again if you wish to with a blue slip.
No corners have been cut on this build and everything is overkill for the power it is making which has been designed that way so it is as reliable as possible.
I am after 36k which includes all 8 rims and a 2 year old 15 foot beaver tail trailer which the car gets onto at this height. Can sell without rims or trailer if need be. Will only swap for an R34 gtr with necessary cash adjustment.
Best to contact me on 0403858714 and serious buyers only please. Located in Rouse Hill, NSW, 2155. Plates only for display purposes and are not included.
Thanks,
Brett
https://www.sau.com.au/forums/topic/416525-heavily-modified-1993-nissan-180sx/
What made you take out the RB26? This car is simply amazing.
I've blown a fair few rb26's drifting and it gets pretty expensive so for the power required to be competitive and spin 265's easily an sr is the most reliable choice :)
That sounds fair haha. Love the car!
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
