rb25det series 1 afm green label great upgrade for rb26 I've got 2
$60 or 100 for both
r33 gtst rear 5 stud conversion
hubs
rotors
calipers etc
$200
r33 gtst front hubs, rotors and brakes good for 5 stud
$200
r33 gtst drive shafts
great condition
$40ea
r33 rear cradle just the cradle
$20
r33 r34 king springs
$50
r33 gtst brake master complete non abs
great condition
$20
r33 manual conversion
comes with everything
Rb25 gearbox
one peice tailshaft
bradied line
both pedals
slave and master cylinders
clutch
flywheel
$1500
r33 engine crossmember perfect for rb conversions
$70
R33 power steer rack
Great condition
$40
R33 rear factory strut brace
$20
r33 front sway bar
$20
r33 series 1 behind the dash aircon stuff
make a offer
r33 series 1 window trims from door and car the one that always fade
make a offer
r33 overflow bottle
$10
r33 gtst turbo back 3inch exhaust
$150
r33 fibreglass rear bar looks awesome
prefitted just needs to be painted
$30
R33 gtst ignition barrel and locks with key
Good condition
$130
R33 gtst side mirrors
$20 each
r33 passenger side gaurd with blinker
maroon
$20
R33 series 1 dash
$30
R33 gtst centre console
Good condition
$20
R33 doors complete with glass and wiondow reg etc only missing the door trims
Will separate
good condition
$50 each
R33 gtst tail lights
Great condition
$20 each
R33 glovebox
$20
R33 boot with aftermarket wing/spoiler looks similiar to standard one lights up skyline
$20
R33 handbrake with full handbrake cable to hubs
$30
R33 passenger window reg motor
$35
R33 passenger window switch
$20
R33 bonnet latch and cable
$30
R33 bonnet latch bracket
$20
r33 boot and fuel flap latch assembly
$20
r33 air con unit/display
$20
R33 complete air con set up with everything!
condenser
compressor
dryer
lines etc
$130
i have all the interior plastics etc
So much more just can't think text me or pm me if you need anything
Gold Coast can post
0487924497
https://www.sau.com.au/forums/topic/416528-r33-s1-parts-wrecking-2-cars/
hey mate do you have the under dash part of the AC? the evaporator is the part we are after as ours is leaking
also what are the king springs you have? we have a stock R33 S1 4 door and want to lower it a bit
can pick up no dramas
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
