i have a rb20det (silvertop) 5 speed s13 silvia front cut for sale..... its all running and can be started within 2 seconds :( runs great ,gearbox also is great no panels or dash etc..... ideal for anyone wanting a rb20det silvia!!!! bolt it all straight in and away u go.... all the wiring is done too so its very easy to copy.....
this was actually a mates car before it was smashed and then cut up.... the engine has around the 70k on it from what we gather from what he was told when he bought the car .... TOKYO TOYS in bris did the original conversion so it was professionally done so at-least u know its all been done right :D...
a compression test was done on this engine by myself and it had a variance of 3 or so psi between all 6 cylinders so the engine is in very good health.... if it seals the deal this can be done infront of anyone with the cash to buy it....
price is $2200 ono .... will be started and run for any prespective buyers....located in toowoomba qld..... thanks guys...
Im interested, iv got a 180sx with a blown engine that this would fit in to nicely, can you send pics of the conversion to [email protected], also does this have a tail shaft and everything that is needed to fit it in to a s13??
thanks
tris
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
