A cruise before most of us have to head back to work? Why not!
Planning to meet at the Aspley Maccas at 1pm on Saturday the 5th of Jan.
Route is heading over Glorious out to Kilcoy and back over Mt Mee (yes Michael, just copied that part).
Understand that it's short notice but would be great to see everyone.
As per usual, knob-like behaviour won't be tolerated.
See you Saturday!
https://www.sau.com.au/forums/topic/416543-new-year-cruise/
  • Replies 65
