[Vic] R31 Gts , Rb30, Rb26, Vlt And More
R31 Skyline Bits
GTS II rear bar fiberglass 4 piece bar in Nissanclassic white (Paint was bubbling on middle section where it is now sanded) $550
R31 Std Brake Master Cylinder $25
R31 Std brake master Cylinder with Booster $35
HR31 Import brake boost and master cylinder. $60
Brand new R31 Wagon Fuel pump assembly $50.00
R31 Series II Ti center console fascia with pocket $30.00
Nolathane Steering Bush for R31 $20
Series III front bonnet catch support and upright $30
Series III front Bonnet Support with catch $20
R31 Power Steering pump in good condition $50
R31 Power steering pump that requires rebuild $10
General
Genuine Bosch 040 Fuel pump 5000 kms old good condition$60.00
Autometer Boost Gauge slightly dented $30.00
Autometer Water Temp Gauge $35
Earls -10 Oil cooler fitting for braided hose $50
New Earls Oil cooler sandwich plate for RB engine (useslarger for Z9 oil filter) Missing O ring $60.00
Large LONG Oil cooler used $50
Ford EL thermo fans trimmed to fit R31 Radiator $40
RB30 Bits
Stage 3 nizpro equivalent cam with new performance valvesprings $180
VLT Dump pipe with Cat (Came off and R31) $80.00
VLT Heath shield $60.00
Nissan Rocker Cover Paint stripped and painted WrinkleBlack (Needs std breather fittings fitted)$60
Std Series III RB30 Wiring loom in good condition(missing the plus that connects to the dash and water temp plug is a bitcracked) $40
Manual Engine Backing plate $30
RB30 started motor (unknown condition was told it works)$30
**VL Turbo Kit Including** $680.00
VL T3 Std Turbo ( came off a running car not blowingsmoke not excessive shaft play
VLT Exhaust manifold
VLT Metal Oil and water lines
Water return pipe to heater hoses
Oil Drain fitting for the block
Rubber Intake pipe
ExhaustWorx 3" Dump pipe
Std R31 ecu (Can be used to have a nistune fitted)
New Turbo to manifold gasket
New Dump pipe Gasket
VLT Crossover Pipe
Water Banjo Bolts
Various silicone hose
Custom Metal Intake pipe with breather and vaccumefittings
New exhaust manifold to head gasket
**Items not in the Kit**
Injectors (the ones that were with the kit were leakingand stuffed so I would advise new or GT-R if you are going nistune)
Oil Banjo into the block
Copper washers for the banjo bolts.
RB26 Bits
R32 GT-R Intake Plenum freshly stripped, powder coated satinblack $300.00
Twin turbo pipe in std silver wit elbow for rear turbo ingood condition $80.00
R32 GT-R engine loom in good condition $160.00
Throttle Bracket (one of the arms is slightly bent eastto straighten) $40.00
Wheels
4x R31 TI 15" wheels with centre caps ( 2 of thetyres have 30% tread the other 2 are 90%) $300
2 x Work XT7's 4 Stud 17x9 + 18 powder coated black with Toyo R1R tyres 95% tread 235/40/17 $1049 ($850.00 without Tryes)
Email me collins.andrew.acATgmail.com
or sms 0434425026
Located near bayswater vic and can post at buyers expense.
  • 6 months later...
 Share
