Got a white series 2 r33 gtst I'm breaking.
Has complete interior.
Small tear on drivers seat.
Dash climate control all good.
Basically brand new splitfires. Literary on the car for 15mins then it was written off. $450
Tein ha front coilovers. Goof cond. $450
Front Lcas $150
Front hubs/ discs rotors $350.
Rack. Has new ends. $100
Cross member and mounts (steel) $150
Castor arms w super pro bushings $100
Complete front bar $300
Fiberglass guards $400 good condition fit really well
Bonnet $100
Got some other lil bits hear and there will update as I go
Chatswood
0419469108 msg for pics. Will put photo s up when I can asses computer
Cheers
https://www.sau.com.au/forums/topic/416550-breaking-r33-gtst-series-2-sydney/
forgot to mention car is non abs.
bonnet and front bar sold- pending.
front mount sold.
washer bottle sold.
gearbox/mounts and tailshaft sold.
alternator sold.
power FC has a tune for a highflow and usaual mods $850 w controller
non abs bm44 $50
Tein front coilovers good gond. no leaks, everything works adjustable dampeners $400
drivers switch ass. $40
Front five stud, brakes rotors $450. pads have heaps of meet. will throu in the hub.
fibreglas gaurds $350 pair. good cond. surprisingly fit really well
splitfire s $400.
hit me up for pieces i havent mentioned. still have more to put up.
and again, im in chatswood sydney.
0419469108
switch ass sold.
bar a bonnet sold
grill sold
drivers window reg sold.
centre console sold.
steering wheel sold.
cluster - pending.
still have front and rear seats pass window reg and trim. drivers trim.
still have front lights.
nissan strut bars
fiberglass gaurds.
both taillights, l/h side indicator lense has a crack in corner. right hand is good
have boot with wing (no brake light $100)
recently recoed radiator and good shroud $80
left hand mirror, faded slightly. works fine $50
pass headlight $150
driver headlight $150. will do pair for $250.
rear strut bar $50
left hand skirt $100. have the passenger as well but will need to be re painted/ or even repaired
ces type ? split dump 3 inch. merges back into exhaust. top quality
catco cat
from cat back its a 3.5inch system,genuine fujitsubo giken exhaust system and muffler w 4inch outlet. top quality exhaust $500
castor rods will super pro bushs $80
also selling a genuine Garret Gt3076 0.82 housed Ex Gated 4 bolt housing $1200- Has elbow welded to it for clearance on 1jz -still on my car and can be started/reved etc - 3-4000km use if that "track car"
Splitfires
Exhaust sold
Forgot to say have injectors supposedly they are 740cc they look like high flows.
Come in rail w reg. Spindles in top condition.
Also got a good coil pack loom. ( still soft)
Good full engine loom UN cut
Good injector loom
Castor arms $50
Tein front coilovers $400.
Lcas 150 delivered.
Cluster $40. Has 145k on it.
Clutch pedal $50
Standard coil packs $50
Standard seats $200
Door trims $40 each or $50 for pair
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
