  • Replies 66
Might want to be a bit more specific and maybe have some pics. Bottom line though, unless its close to completely stock, in original condition, with low k's and paperwork to back it up, you'd struggle getting any kind of a premium over a normal 32 GTR.
Where abouts on the block would it be? Yeah I had a guy a on here fast it for me. Vin numbers BNR32-100352
Its on the turbo side, somewhere near the front turbo. Take the under tray off and look from under the car. It will say 24U if it has an N1 block and 05U if it has a regular RB26. You'll see 05U on the head so do be confused by that.
If you look at the underside of the block forward of the front turbo, and it has "24U" embossed on it like Adam stated, it's an N1 block. Does it have this?
What does your paperwork say? Pics will be good. What tells you that your car is a "Nismo Edition"?
If Nismo had ownership of this car in Japan, they may have simply utilised a V-Spec N1 > and now you're checking this out.
Can you put up pics?
Do the Nismo editions have an N1 block?
Has anyone ever found a part number for an N1 block in the R32 GT-R fast system? My local dealer cant find it, said it began with the R33 series? However, there were specific parts for the turbo charger, oil and water pumps ect listed.
No matter what the car is a genuine Nismo with that chassis number, car number 352 to be exact!
I'm gunna jack it up this arvo and have a good look. And tomorrow I will upload photos :). Yeah she's definately a Nismo, I had someone on here fast it and a mate of mine who knows a shitload about GTR's checked it up for me too.
Nismo edition's Vin numbers start from Bnr32100000 - 1000560. I'm also pretty sure they came with a standard block, well mine did anyway.
I was thinking the same thing about 05U Block and the turbo's are Nismo items.
although it might be a nismo, it's been resprayed and unfortunately that defeats the purpose of owning one of these and may reduce the price significantly
They only ever came out in gunmetal grey, other than the body kit, the only other obvious tell-tale sign is the white vinyl sticker on the rear and the vin number,
it should also be missing a rear wiper blade assembly, abs should also be missing and in some cases, on the dash controls, the radio button should be missing too
Can anyone tell me what an R32 GTR Nismo Edition would be worth? Im looking to sell mine and when I bought it the bloke didn't know what he had so I was just looking at what they're really worth.
From my own extensive research over the years, the Nismo edition is worth slightly more than a standard R32 GTR but less than a Vspec 1 or 2, for a comparative condition car. That puts you roughly in the broad 10K-20K range, however it is only worth what somebody is prepared to pay for it- Originality is the key.
The Nismo spec version is not very highly regarded by collectors in Japan either, even though built in limited numbers, much less than Vspec 1 or 2's build numbers.
I wonder why that is? I always thought that it would be the other way around.
Hi mate I'm also thinking of selling my r32 gtr nismo edition bnr32100108, mine has had a full overhaul, and respray, personally I couldn't let mine go anything less than $30000 Shannon's valued at this and that's what it's insured for
Edited by Ozco
You'd be flat pressed getting 30 grand for an R32 GTR that isn't mint (and I mean like brand new mint) or very cleanly highly modified.
I tried telling him that in his for sale thread.
And the fact its been resprayed = instantly devalued.
Could be a factory respray, which is really the same.
No, because even when using the factory colour, its easy to tell when a car has been respray. Use a paint thickness micrometer and it wont be the same consistency and thickness as the factory paintjob.
A car to command a premium must have the original paint/panels. People want a car that has a body that is as close to possible to when it rolled off the factory line.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
