hey guys,
i have been getting some poor radio reception on some stations in certain areas and poor reception on one station in all areas (96.1).
is this a deck or antenna related problem?
Is there something i can buy to boost the antenna reception?
any help much appreciated.
hey guys,
That is so vaugue , how the hell can we troubleshoot that haha
What city?
Weather at the time?
speed?
model of car?
Type of radio?
Type of antenna / stock or ?
jap freq expander ?
cut antenna wires soldered job?
mountains/ buildings / metal / concrete or a million other things affect it
Yes you can amplify the signal , most on time in the city it overloads the PLL circuit and you get multipath ( picket fence sound as you move or mutiple stations )
try a handheld radio in the same area ?
Or use a smart phone to run the digital signal off net ?
sorry my bad haha
Sydney metro
weather (doesn't matter whether its sunny/rain/hail) the one station is still crap
very rare do i get clear signal for a few seconds but it is still very distorty
speed (doesn't matter as it is same as weather)
evo 7
alpine IVA-W200E
no jap freq expander (had this on my skyline with the jap deck and it was sh*t, changed to a aus deck and had crystal clear radio reception)
standard antenna/aerial on the car
no cut antenna wires from what i can see.
i bought a fm 12v signal booster online and will try that and see how it goes.
evo 7 has an amplified antenna. is tht powered. there should be a single pin plug on te main harness. wire shoukd be yellow. power that and you should have radio again. fm booster wont help. those are a waste of money.
Yep exactly those "amp antenna inline boosters "dont work they just over power the radios fm
and create other problems
That alpine with a 2 dollar antenna should work great?
Funny enough I drove a friends lancer VRX in that vintage a lot and the stock top spec radio it had issues with fm dropout and stereo sound drop off no matter where the car was in town or out , never did dig into why but it might be a common cause lile a broken antenna mast internally ?
just an update,
the P.ANT from the deck was not connected so i wired it to the yellow wire as stated by Chris Rogers,
it helped but not by much, the main channel i want (96.1) is still fuzzy :(
so does that mean it is either my deck or my antenna?
    • Nah, just take the other one off too
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
