  • 1 year later...
i got one of those greddy full auto timers. having trauma, ive taken pics and stuff, but because i cant read japanese figuring out which wire goes where is a bit hard.
the harness and earthing wire and handbrake wire i can figure out just fine, but i have another two wires which im assuming are rpm signal and speed sensor wires. if anyone knows whcih one is what let me know.
once i figure it all out ill take pics and post up new tutorials, since these pics arnt working. wish me luck!
I got a blitz FATT X. I trying to connect the wire myself. does anyone know which is the accessory wire for skyline R33 S2 ?
I know there are 5 wires which is
Red - 12v
Black - Ground
Purple - HAndbrake
Blue - Accessory
Green - Ignition
I just dunno which for blue to connect with. can anyone help me?
  • 4 weeks later...
while on the topic of installing turbotimers and alarms and the sort, i would NOT recommend AutoMotiv from sydney to do any installations. they totally FKD up my alarm and fried my turbo timer, and wont fix anything coz they claim the original turbo was wired wrong (yet stupidly they still wired straight into it anyway). so now i have a c car with a fried alarm and turbo timer...f'ing pricks. id never go back there...
man i really feel for you with that, probably the worst possible outcome that could have happened :(
  • 1 year later...
i have a rb25det swap on my s13 and Have a Greddy turbo timer and i already installed it. workds great. but at the end theres two other wires...( brown and purple) the brown goes to the e brake witch i already put and it works every time i try to release the ebrake after i have pulled the key. but the purple wire, i dont know were to put it, i know it goes to an ecu wire but i dont know witch one? can anyone help?
it says connect purple wire to speed signal wire on ecu but which one is the speed signal wire?
http://www.greddy.com/img/PHP/products/pdf/685.pdf
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
