EOI My Type X 180sx street/drift/circuit ($20,000)
Ben 0400705710
Brisbane
Mount Cotton
[email protected]
Bodywork:
10 piece GP Sports bodykit including metal widebody front gaurds
Roof spoiler and Duck tail boot spoiler
Koguchi Power bonnet
Ganador Mirrors
... Carbon fibre centre taillight Garnish
Interior:
Bride Zeta III Red Fixed back drivers seat with head pillow and lumber support cushion
Bride Brix II Red passenger seat
Nardi Deep Corn Suede steering wheel with NRG Tilt and short boss kit
Red Louis Vuitton Door cards and Glovebox
Defi water temp gauge
Defi Boost gauge
Blue led dash lights
Panasonic Head unit
Allpine speakers
Allpine tweeters
Apexi Power FC ECU with hand controller
Greddy Profec-B Boost controller
Pivot Headlight controller
Half Cage
Rear strut brace
Stripped and painted boot
Battery relocated to boot
Engine: (60,000kms)
SR20DET
S14 BB T28 turbo
HKS Actuator
6Boost manifold
Stainless Dump
3inch Titanium Pipes RC Exhaust
Titanium Cannon
Greddy Front mount intercooler kit
Oil filter relocator and oil cooler kit
Pod filter with Z32 airflow meter
Nismo 550cc injectors
Stainless catch can
Strut tower brace
Weld spark plug cover
NGK Iridium spark plugs
S14 5speed gearbox
2way mechanical LSD
S14 5stud
ABS removed
Steering rack relocated 25mm forward
Polyurethane steering rack bushes
Swaybars
Suspension
CST adjustable Coilovers & Shocks
Camber Arms
Toe Arms
Tein Castor Rods
Comes on staggered CST Hyper 01 17:18 9.5J +15
SERIOUS INTEREST ONLY PLEASE Contact for more info.
https://www.sau.com.au/forums/topic/416944-type-x-180sx-streetdriftcircuit/
  • 3 weeks later...
  • 3 months later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
