hey guys, have a few things for sale since i sold my gtr
2 x z32 afms's with apexi air cleaners and hks rubber pipe and hose clamps, no plugs - $400
gates racing timing belt kit (missing the pulley with notches in it. so belt, 2 seals, 2 smooth pullys) - $125
defi link control unit series 2 ( 6 buttons on the front) - $200
defi gauges x 4 white red light.... oil press, oil temp, boost, water temp, with sensors and two gauge holders, all gauges sit in plastic housing - $400
greddy turbo timer - $100
can post at buyers expense. should be around $10-$20 anywhere i think and located near rockhampton qld. text 0400750335 for info and ill take some pics tomorrow to send around if anyone is interested. thanks
2 x z32 afms's with apexi air cleaners and hks rubber pipe and hose clamps, no plugs - $300
gates racing timing belt kit (missing the pulley with notches in it. so belt, 2 seals, 2 smooth pullys) - $90
defi link control unit series 2 ( 6 buttons on the front) - $150
defi gauges x 4 white red light.... oil press, oil temp, boost, water temp, with sensors and two gauge holders, all gauges sit in plastic housing - $250
greddy turbo timer - $50
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
