Alright guys i have a USDM s14 with a RB25det Neo, FMIC, walbro fuel pump, Wiring spec Harness Drives idles etc .. Anyways I used Consult 2 to read codes out of the OBD1 port and some of the codes i knew i would have IE Boost sensor, ABS, TCS but its throwing a TPS code also which it has thrown 2 times. I have 6 wires coming off my TPS so im assumming that it is a Auto Engine? It is also throwing a TAC module. Idle is 1300 when warm just found that out last night via Consult 2 cold is 1700 when using Consult i can manuely turn on the ACC and drops to 750ish and holds. So to get the Point is the TAC needed? and is it throwing TPS code cause only the top half of the TPS is plugged in?
https://www.sau.com.au/forums/topic/416977-rb25det-neo-s14-question/
Alright update on whats going on. 3.33v TPS closed adjusted it as much as possibe and could only sqeeze out 2.567v made it better but still not right.... Im going to replace the TPS saturday, When thing I cant find is what the bottom 3 strands of wires are used for ? is that for the a/t control module?
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
