  • Replies 347
Haha considering the fact that a rb20e only has around 100kw, thats a 0-100 time of 10 seconds ish. (from calculation of the 147kw rb25de 0-100 8 seconds).
I'd love to see a rb20e try to do a 10 sec 100. Some poor bugger has one in aust. They should do a test.
There's a bunch of em kicking about, pre sevs imports. A few in HR31s as well.
In response to OP:
Are we counting Rotary N/A?
They're pretty quick but that's more about having a lightweight body than having bucketloads of power.
Hate to burst this bubble of worship guys, but NA rotories, still slow.
Even the panspeed car only had like 500HP
Worked 20B.
Dill with it.
Worked 20B.
Dill with it.
*Cough* Not slow when bolted into an 800kg r100... *cough*
Yeah, but that's the point, you HAVE to bolt it into something that is sub 1000kg to make it go hard.
Don't get me wrong, I do appreciate my normally aspirated rotangs.
Just sayin'
Just sayin'
Same theory as cortinas, average motor bolted into something light = fastish
NA skylines are the same as a decaf skim latte.
Why bother.
Because then u get to hang out with the cool kids in the coffee shop, same principle.
Yes a commo will smash ur Natro skyline, but with the skyline silvia 300zx soarer whatever it may be they're Natro versions are still "welcomed" to events such as down shift meet ups, club cruises and jamboree.
It's a conformist/wanting to belong to something thing
Hey hey hey, I've just got wiring left now ;)
ive just got the exhaust left.
whats your point?
I will laugh when my rotang starts before both of your cars ;)
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
