vids or didn't happen.
I want a highly detailed oil painting of the event
He gets out sideways at 140km must be rajab himself. Lol stupid kid
Hmm if I lean on mine I reckon i could get sideways at 150 in the wet, do I now become king over l0rd (since when did l0rd auto correct to son of rajab?) of the p platers?
Lots of his mates told him so
Yes, I give you the most reliable source of driving talent judging... *Points to Johnno standing next to his superepcobahn spec VC*
  • Replies 347
  • 3 weeks later...
we (pplaters) would love to have turbos. we learn to drive in n/as and obviously covet more power. but i myself love to drive fast and hard and i can happily out handle most cars on a windy road because i actually know how to drive. (told by many, including turbo owners that i can drive well and have impressed even them.) our measly n/as are generally also limited to 180kms and that sucks.
id just like to say to the guys who mentioned about breaking 140km+ in his turbo.. that obviously i cant break traction at 140.... but i am really good at breaking traction and high speed drifting rally style on dirts roads at 160kms and know what the hell im doing. i dont care if you have a turbo, id like to see you without stained pants after i take you for a rally sesh. ya smirf!!!
oh and forgot to point this out... All of the jdms are limited to 180kmh...
Nuh-uh. He just told me n/ays are limited to 180. not turbo.
  • 1 month later...
Thats kinda a hard question and you will get plenty mixed results, it all comes down to the driver and how they drive there car as to what they will say. I own a r33 NA and im in love with my car, all the work ive done is a pod filter and im in no rush to do mods, ive driven a wrx before so i know what a turboed car feels like and yes id like that feel with my car but for now im happy, ive got a year and a half maybe till im on my opens and till then ill happily stay NA, My cars not fast but its also not slow, all these ppl saying there slugs and such have probably owned and/or driven some fast modded and turboed cars and then their just comparing to those cars and of course compared to something worked on and such an NA vehicle will seem slow. its all up to you as to what you drive and how you feel about it.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
