The Wasteland 2013 Edition
heslo
 Share
to the knob head in the gun metal 32 driving from Golden grove road onto the grove way (semi sideways) then right onto Atlantis drive, you are a Di@k head. If i had a bull bar on my car i would have followed you and made sure you wouldn't do it again. if you are on here pull your head in you make it worse for the people who drive these cars and respect the rules.
end rant
^^^ so true. Who on earth go would and sit by the side of the road in one spot to see a pack of cyclists whiz past you, and that is it? Sounds like the definition of boredom to me. And 757k? That is more than half the population of SA - I don't know a single person who went for a look, so by those odds I would say very incorrect. And how on earth would they even come up with that number?
Andrew- the calculation is: 757,000 divided by the number of days it ran for = the number of people per day that had their time wasted by "who dares to use the newest drug wins"
assuming it was the same people that attended every day, the divided number is the true number
Edited by Deep Dish V35
Don't you just hate it when you swap out a non working dash cluster for the new one only to forget to change the LED globes out from the old to the new....
It dawned on me just as I was tightening the final screw.... Doh :/
Walked out the door, took photos , walked back in , downloaded to laptop 3times for stage 5 lol then published to adlelaide now and a few other spots
Actually the beach front had a lot more people this year compared to the past 3
Would anyone be interested in putting their skyline/stagea into a free car display at Virginia on 14 April?
There is a market happening there from 10-2pm and they'd like to have 10-12 skylines on display.
12 cars means you could get a coupe sedan and gtr of every generation.... which would be a good display
 Share
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
