Expert opinion? Once you start ticking the options on those RCR kits, they get pretty f**king expensive. Add on drivetrain, shipping, local engineering..
Cost / expense and worth are 2 different things
he paid 190 for it. it is worth it once you drive it;)
the other one in adelaide cost a bit less than that as he built most of it himself (120K so far) compaired to this one that was fully built in the QLD factory.
woah def not worth that much for a kit car.
if you saw it in the flesh (or lucky enough to drive it, which i have at speed) it is worth it. the 7L engine was 35K alone from the US gearbox another 20K . the engineering is a work of art. it weighs just on 1000kg and has 'around' 500KW at the wheels:)
to those who may or may not know (and to those that don't care) i became a daddy for the first time on the 23/4 at 0052. we named our first child Jameson Seeley
Congratulations man. Now to start saving for a gokart lol
Went out to watch the drift practice with Krishy tonight.... There was some big crashes and a rollover right in front of us... Thankfully no body hurt (well badly) from what I could tell... not a bad evening :)
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
