need a lil help guys, was driving the gtr just cruising at 60 changed gears nice n slow n I felt a funny twitch in the clutch pedal and then next time I pushed the clutch is was a lot heavier all of sudden.
pulled over check the fluid levels all looks ok, then I noticed when I got back in it every time I pushed the clutch it was making a noise like gas escaping. This was in the car not under the bonnet.
so I hear this is possibly a vacuum leak in the booster? anyone got any other ideas?
anyways I drove it home and it felt fine aside from the weird noise and being heavier clutch than normal, went into gear fine no crunch.
What im wondering is, is this doing any damage to the clutch? I have the nismo coppermix twinplate so I don’t wanna stuff it up but its normally light as a feather and id actually prefer a heavier clutch pedal.
o and this car is starting to p me off
Edited by Inline 6
Sounds like a throw out bearing... Or more likely a split in the clutch vacuum booster pot steel casing...
Check and see if the noise is coming from the clutch pedal pivot area.. With the pedal getting heavy though I would say that it is the booster...
I hope it is nothing worse than that...
It's gotta be the booster Dan. If it was anything else it would be crunching/notching gears. I wouldn't expect it to be doing any damage to the clutch.
Edited by dark.sky
Get the standard one welded up strong, nismo one is standard with som tack welds to reinforce......
Yeah my mechanic took it out and seem welded it and put a strengthening plate as well... much cheaper than going aftermarket lol
G'day, looking for a little help/advice..
I've been out of the loop when it comes to parts prices and just wanted to know what you guys think. I'm looking to buy a r33 rip the motor and box and replace it with my built stuff. Question is; what are r33 s2 motors + boxes worth now days. Am I dreaming thinking I could get $3000 for both including loom and clutch? Are they still moving fairly quickly or are people not buying them? When I bought mine 4+ years ago, I paid $3500.. I want to know this before I buy the 33 so i know weather or not its a viable option..
Cheers!
Yeah as mentioned above ^^^ best bet is to call a couple of wreckers or import specialists wreckers a call and find out how much all that kit is worth these days. It will give you at least a ball park figure to work with.
Was driving today and this happened, its the left side bracket on a R33 GTR drivers seat. You might also notice it has been welded in 3 places by the previous owner haha. Anyone else had this happen to them?
Also I swapped the passenger side bracket over to this so i can get around, anyone know if a gts seat will have the same bracket?
someone buy my old GTR and give it a good home;
http://www.gumtree.com.au/s-ad/ridgehaven/cars-vans-utes/nissan-skyline-r32-gt-r/1014576914
runs 10's:)
.. it's a shame YOU never ran a 10 in it :D :D :D
Cheers!
Pretty sure you are dreaming - RB26s can be had for that sort of money (I sold one on behalf of my brother-in-law for well under $3k 2 years ago). Generally RB25s hover around the $1,500-$2k mark - maybe a bit more incl. the loom, and if the clutch is decent. But you never know - selling 2nd hand parts is a funny business - sometimes you can barely give things away, and other times you could have sold a thing 10 times over for mor cash then you got.
Yeh I was saying 3k with complete motor (inc. loom, clutch, everything) AND box. I think $1800 for engine and $1200 for box is fairly reasonable.
I know what you mean, I've sold plenty of parts and its just a matter of who wants what at the time. I remember when buying my 25, everyone wanted one. I got mine at $1900 and that was a steal!
oh snap!
Guest
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
