That could make sense I have yet to put the PFC and boost controller on plus do all of the other work. Maybe sell it and buy a completed track car...
Oh and what is wrong with an RX8 :nyaanyaa:
I agree - they are very cool. In fact if they had 50-100 more kw I would own one right now. I was all geared up to buy one when they first came out, but just couldn't take the plunge for that amount of power.
A turbo kit would now solve that though :) *hint hint*
  • Like 1
does anyone even know how much power they make, fuel consumption and the cost of the car b4 they say cool
Then on top of that, the cost to turbo it. They r a nice looking car tho
Full engine rebuild was completed by mildrens recently with a lot of work done... It is one clean car :)
So it's had a new rebuild already despite being a newish car.. welcome to the world of rotary
RX8 gets the nod over the other 2 as well....nice ride
SR20 and RB25 neo r miles infront
Edited by discoPumpkin
Standard they have 177kw & 230 Nm but only weigh 1200kg - A 33 GTST has 187kw and 294Nm and the Skyline weighs just short of 1400KG so there is not a huge difference from stock...
The rebuild was done because my mates car yard bought it as a trade in without checking it properly and the lady owner had let the sump run dry and had pretty much destroyed the engine. The work done to get it back to the yard for sale is exhaustive, 6 pages of parts and labour at over $8k at trade prices of work.
If I had got it done it would have cost me $10k plus for that amount of work even with my contacts. The motor is still being run in as it is only at 500km since done. It is so hard to keep it under 5000rpm at the moment ;) but I love my rotary's and know how to run in a new engine (I have blown a few in my time lol)
I will probably do the exhaust, air induction, ignition and spark upgrade, throttle response upgrade and then reflash the ecu for now.
That will take it up to about 203kw which will be ample for a daily :)
Oh and 0 to 100 it is faster than a 34 and a 33 hahaha
They weigh 1300kg , but a RB25 will make 350rwkw aswell as an SR20 but with a lot more torque then a rotary, where as your moor could make that power it just needs a lot more work and money
It's still a good daily driver tho, has all the electrics and comfort etc. Don't get me wrong nothing beats the sound of a rotor, I love them myself but u need deep pockets to run them but its good u got one that just was rebuilt.
ps keep feeding it plenty of oil so it doesn't run dry again
Like I said standard they make 177kw... there are plenty of RX8's that make 300kw + with about the same work as a skyline... $8k to $10k and you are there.
I have had plenty of Rotary's from 13B PP to 20B's with power that would shock and destroy most skylines... Only problem was average engine life between rebuilds was only 6 months when running those engines :(
Correct me if Im wrong.....
I baby my RB25 (rebuilt) these days. If I DO flatten it (very rarely, like once in 800kms) a nice cloud of black smoke is left behind.
Just carbon deposits in the exhaust, plus richness of tune?
I just saw this and thought it was funny.
A nightly prayer for the car enthusiast...
As I lay rubber down the street,
I pray for traction I can keep,
But if I spin and start to slide,
Please dear god protect my sweet ride.
Guest
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
