So I imagine that the original issue was that the rings were never bedded in correctly?
I suppose this is testament which proves the "get load on the engine ASAP" run in method.
What run in method was originally used?
Glad to hear you have it under control!
I'll be interested to see how mine goes if/when I get down to Collie, venting the sump seems to make all the difference
I think nearly everyone will be - if only because I can now stop sulking about it.
Possibly to probably. Certainly the original engine had far too much blowby which is usually an assembly issue and given the workshop who built it specced it, installed it, fired it up and ran it in - if it wasnt an assembly issue then it is/was still their issue. By the time I got to confirming how it was all done I was so far over talking the said workshop and generally dealing with their &^%$ I never did ask.
For what it is worth having spoken to a number of other engine builders and to Pacific Engine Parts themselves the CRC + drive it on start up (ie dont let it sit at idle) is the way I would be doing all engines in the future.
Also for wha it is worth I rechecked on the oil return diameters in the old block. They are 8mm which is slightly larger than the head. The head got drilled to match the block - which is porbably a mm or so smaller than most people do. Anyway those five returns probably add up to well under half of the total return area.
Edited by djr81
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
